losing the junkyard transmission gamble?
Old 08-06-2014, 03:01 PM
scallajandro's Avatar
Hey folks- I've got an '89 pickup with a 22re, 4wd. i've had it 2 years & the transmissions been bad since i've had it. last month the clutch wore out, so I got a tranny from a junkyard & had a mechanic put that in along with a new clutch assembly. This transmission whines in 3rd and 5th and is still very hard to shift. i was thinking about changing the fluid to the redline mt90 i've been hearing about, & need to know how much i'll need and if there is any chance it will make anything better.
Old 08-06-2014, 04:00 PM
rattlewagon's Avatar
Could be the shifter seat is worn? Cheap fix thanks to Mr Marlin. https://www.marlincrawler.com/hardwa...-forward-shift
What makes it hard to shift? Grinding? not finding gears? Just sluggish?
Welcome to the forum!
Old 08-06-2014, 04:51 PM
it grinds a little going into 3rd. the worst is trying to go from N into 1st. no grinding, just very hard to put in gear, to where you feel like youre just going to break something. shifts through the gears OK while driving. a little sluggish though.
Old 08-06-2014, 05:24 PM
Nervo19's Avatar
New shifter seats cured the "hard to get into 1st gear" in mine.
Old 08-06-2014, 05:28 PM
Well for the price i have no reason not to try the shifter seat, so i'll get on that soon. thanks guys!
Old 08-06-2014, 09:06 PM
Daddyota's Avatar
Just curious, how much were you able to pick it up for and how much was the Install? I am going to do the exact same thing soon with a junkyard donor. Hope the shifter seat fixes it. Also check your fluid level. I had a leaky slave and it made it impossible to go into 1st.
Old 08-06-2014, 10:50 PM
millball's Avatar
I rolled the dice on a junkyard W56b tranny and transfer case last December, for my '87 4Runner. Paid $200 from a yard in Tucson, but had to remove it from the wreck myself.
Bought Marlin boots, shifter seat and socket. Aisin clutch kit from Ebay cost about $115.
Wife and I stabbed it into the truck on Christmas afternoon........ Priceless.
Tranny and transfer case are perfect.
Every once in a while, things just turn out right
My condolences to the OP.
Old 08-07-2014, 03:18 AM
I got the transmission for 300 plus core charge, & the yard delivered it to my workplace which was nice cause it was about an hour from my house. then about 100 for clutch kit, and i paid 450 for the install. he also put in new cylinders & that fluid level looks good. not a bad deal, just gotta see if i can get it working a little better.
Old 08-08-2014, 05:10 AM
boxer.fan's Avatar
So lucky to have a wife wrench with you. Mine would rather buy me a new truck than help me with my"old truck" but I'm not having that!
Old 08-08-2014, 10:38 AM
Staff
Terrys87's Avatar
I bought one and it had the 5th gear whine, it had been sitting for 4 years according to the owner. After about 100 miles the whine went away. If it had the whine and wasnt sitting very long, chance are it will never go away. I tried the fluid changes and different fluids and never did get rid of the whine.
Typically the cost around here to change a clutch is $600 and that does include the parts and getting the flywheel resurfaced. Probably an average price across the country, give or take a few dollars.
Any more now when I change a clutch, I just go ahead and get a new slave cylinder. Seems like in the past I would change the clutch a within a year the slave cylinder would go bad. Now I just do it all at once to save the headache of doing it again later.
Liadrin
04-25-2022 02:54 PM
theking11863
03-19-2016 09:36 PM
Liadrin
09-01-2015 06:44 AM
Lochsa
08-02-2015 02:51 PM
TDonkey
07-26-2015 10:14 AM
Quick Reply: losing the junkyard transmission gamble?
