Loping with the brakes? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-14-2009, 06:00 PM   #1 (permalink)
Help please,
I had this same issue with my 22re, but my 3.slow 4 runner now is loping when I step ion the braskes. Also the brake light on dash glows dim and occasionally gets brighter and dimmer. I thought maybe I had a vacuum leak but cant seem to find one. Any ideas? All input is aweesome. Thanks.
Rift
RiftRider is offline
Old 11-14-2009, 06:46 PM   #2 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
You posted this in the for sale section.
Moved to 86-95 section
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by AustinTaco View Post
the last person to work on the front used the "chizzel my dizzel" method
DeathCougar is offline
Old 11-14-2009, 06:49 PM   #3 (permalink)
turboboost's Avatar
Check your fluid level.
__________________
1990 Toyota 4Runner - SR5, 22RE, 5 speed, 35" Mud King XT, a bunch of mods.
1986 Mazda B2000 - 5 speed, carb'd 2.0, the winter beater.
1979 Datsun 280zx - 2 seater, 5 speed, stripped interior, etc.
1998 Nissan Altima - 5 speed, 1981 280zx turbo snowflake rims.
1985 Toyota Pickup - SR5, 22RE, 5 speed, Xtra cab, lifted 2", 35" boggers, etc - Sold
1983 Datsun 280zx - Turbo Intercooled L28ET - Crushed.
1985 Nissan 300zx - 5 speed, race prepped, etc - Crushed.
IFS Club #7
turboboost is offline
Old 11-14-2009, 06:53 PM   #4 (permalink)
Loping? You mean pulsing? If so does it feel more in the floor or steering wheel? If wheel, I'd say get your rotors trimmed. If floor (or I like to use the e-brake trick) get the drums trimmed.
wd21_sr5 is offline
Old 11-14-2009, 08:45 PM   #5 (permalink)
Matt16's Avatar
No, the engine idle is loping.
Try adjusting your idle and reseting it to the proper speed.
__________________
1990 Toyota 4Runner 22RE 5spd
*Aussie Locker*York OBA*
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Quote:
Originally Posted by DeathCougar View Post
next time when the front of your engine sounds like a can of spoons, fix it
Toyota FAQ link
More info on 4Runners
Matt16 is offline
Old 11-15-2009, 01:46 AM   #6 (permalink)
Send a message via MSN to aerocorey
Loping engine when stepping on brake pedal is brake booster issue. Not real sure about Yotas, but on Full Sized Jeeps there's a check valve that can be replaced. My Grand Wag's idle would increase when I hit the brakes. I couldn't find a leak, but I replaced the booster anyway. I hadn't realized how bad my brakes sucked until I drove it with the new booster, and my idle smoothed out. I'd download the FSM that's available on this site, get into the brake section, and troubleshoot the booster. Or just replace it.
__________________
Corey
'94 3.0 5 speed
aerocorey is offline
Old 11-15-2009, 08:38 AM   #7 (permalink)
Junkers88's Avatar
What is the engine idle speed set to. I'll bet you money it's too high and that is causing the loping idle.
__________________
RB4R-P.
1989 SR5 4runner. Tread Wright 31/10.50/15's. 4.56 thirds, an Aussie in the @$$, Budbuilt plate, Marlin Crawler front, modified MC rear, Supra MAF conversion, ZUK coils in the rear,4crawler BJ's in the front, LCE header.
Junkers88 is offline
Old 11-15-2009, 08:58 PM   #8 (permalink)
Thanks
I am not sure what the idle is set at, it idles about 1200 even after its warm.
It should idle about 900-1000. When I swap the booster Ill post my results.
Thanks
Old 11-15-2009, 09:29 PM   #9 (permalink)
abecedarian's Avatar
Umm... if it idles at about 1200 after warm, that's where the idle is set at. If you think it should be 900-1000, you already know the idle isn't where it's supposed to be, right?
For the record, it should be around 850. 800 is too low, 900 is too high.
Set the idle and ignition timing before you change the booster. You might be pleasantly surprised.
__________________
Why do people run the dishwasher and walk the dog?
I would love to go look but I'm too busy sorting my random coin flip collection.
abecedarian is offline
Old 11-16-2009, 08:08 AM   #10 (permalink)
I'm sorry, how does a high idle result in a loping loping? I can't make mine lope by adjusting the idle. I must be missing a fact here...
__________________
Corey
'94 3.0 5 speed
Old 11-16-2009, 10:53 AM   #11 (permalink)
Junkers88's Avatar
Quote:
I'd love to get into it but the answer has been posted dozens of times, by me on several of those. Do a quick search and I'm sure you'll find it.
__________________
RB4R-P.
Old 11-16-2009, 01:36 PM   #12 (permalink)
Here's the reference Junkers is talking about:
"Assuming there are no vacuum leaks, such as in the brake booster, it’s likely because your idle speed is set too high. I can exactly duplicate this “problem” in my ‘85 by bumping up the idle speed to a bit over 1000 RPM and it’ll act as described. Turn the idle speed back to normal, and it works fine. It’s really not a problem, its supposed to work this way and if everything is set properly, and you won’t have the “problem”.
Why is this the case? Because the ECU has logic built in that says if you hit the brakes and the engine is turning over 1000-1100 RPM, it’ll cut the fuel to the injectors in an attempt to help you stop faster. After all, no sense pumping gas into the engine when you are braking to a stop. So idle rises, fuel is cut, idle falls, fuel restored, idle rises, etc. Turn the idle back to 850-900 RPM where it’s supposed to be and it’ll get back to normal. Idle speed is adjusted with the large slotted screw atop the throttle body. Turn it in to lower the amount of air passing through the throttle body at idle (and thus lower the idle speed)."
__________________
Corey
'94 3.0 5 speed
Old 12-05-2009, 06:56 AM   #13 (permalink)
aerocorey,
that was an outstanding explanation.i had the same prob. and wasn't sure till i read your post.
rainman88 is offline
Old 12-06-2009, 07:46 PM   #14 (permalink)
Bojangles's Avatar
Ive got the same thing going on with my 97 toyota. I know what im doing tomorrow before work haha Thanks!
Bojangles is offline
Old 12-08-2009, 02:51 PM   #15 (permalink)
Ok that was cool. but another problem arose with it. I set the idle to about 850-900 and the problem went away. About a week or less of normal driving and the idle adjusts itsselt to about 100 (one hundred) RPMS. I reset the IA to about 850-900 again and in about 50 miles the RPMS just back up to 1200. The problem instantly returns. I did not reset the ECU when I made the initial adjustments. Should I have?
Gonna try it and Ill see what happens. Thanks for the help.
Tags
1981, 22re, 4runner, 86, b2000, brake, brakes, high, idle, loping, mazda, pulsating, rear, repair, speed, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
