loose steering wheel
Old 03-26-2016, 10:05 AM
firemanyota89's Avatar
i just bought a 93 single cab pickup dlx 3.0 5 speed 4x4 the steering is a little loose. I just bought the parts to rebuild the front end but it feels like the shaft joint may need replacing, despite my best efforts I have not been able to find the joint. So my question is can I rebuild the shaft with a new joint or what are my options?
Thank you guys and girls.
Old 03-26-2016, 10:20 AM
tj884Rdlx's Avatar
What part do you need here?
That diagram is from this site:
http://toyotaparts.checkeredflag.com...wd=&origin=pla
They list the part numbers so that should help locating the part you want.
Also, have you checked car-part.com for a salvage part? Good site for used parts.
Old 03-26-2016, 10:38 AM
that's what im not sure of could be 1,7,8,9, or 10. I have been trying to find a new one but no luck and now thinking about rebuilding it but don't know how hard it will be or is. I have a decent amount of know how.
Old 03-26-2016, 12:16 PM
scope103's Avatar
My brother had this problem. It turned out to be a loose nut behind the wheel.
Old 03-26-2016, 02:43 PM
wyoming9's Avatar
Red face
Funny I have the loose nut behind the wheel it follows me from vehicle to vehicle Strange !!
If you can`t figure out just what is bad .
After working my way through a steering Column replacing with new parts.
Find a good used one and be done
Old 03-27-2016, 12:00 AM
tj884Rdlx's Avatar
Car-part.com shows steering columns in my area range $55-125. Looks like you must know tilt, floor shift, and manual steering variables for a correct match. Good luck!
Old 03-27-2016, 11:51 AM
Fossilized
Staff
dropzone's Avatar
Part one is just a sleeve that the steering rod goes through.
there is some adjustment that can be made on top of the steering box that may help
kporter
08-31-2009 05:33 PM
slyang1012
09-28-2005 10:25 AM
Quick Reply: loose steering wheel
