Loose steering, what parts should I replace
Old 08-06-2009, 07:33 AM
Fo by Fo's Avatar
So my 1991 4x4 4runner has had wandering steering for a while and I'm finally going to do something about it. I know the control arm bushings are bad, and I'm pretty sure the ball joints are bad as well. I wanted to know what other parts I should pick up and replace while I'm doing the front end. The steering stabilizer is good, replaced that a with OME. Also, would replacing these parts fix the wandering steering? Thanks
Old 08-06-2009, 08:43 AM
crafthorse's Avatar
all your listed parts and Pitman arm, idler arm, inner and outer tie rod ends. I just replaced all the parts on mine and the half shaft CVs for 1200.00
Old 08-06-2009, 09:23 AM
TNRabbit's Avatar
Go ahead & tear down the axles & regrease at a minimum.
Old 08-06-2009, 09:26 AM
Staff
DeathCougar's Avatar
Is that installed?! I hope so, other wise you got hosed!
I did the inner rods, outer rods, pitman arm, and idler arm on Taikowaza's rig and it was under $400 Control arm bushings and ball joints can't be $800! And Tim even bought Toyota parts!
Old 08-06-2009, 09:28 AM
Ardent's Avatar
Last night I bought new Tie Rod Ends and the Pitman arm, all with a Lifetime replacement warranty from Advance Auto for $180.
After a weekend of hard wheeling, this is how it all looks...
Old 08-06-2009, 10:04 AM
Fo by Fo's Avatar
do you mean the pitman and idler arm bushings?
Old 08-06-2009, 05:18 PM
abecedarian's Avatar
I had a whole dissertation prepared but then a simple question popped in my head:
What size tires do you have and what is the offset / backspacing of the wheels?
Old 08-06-2009, 07:21 PM
desertcamper67's Avatar
Just replace the worn ones. How is the steering gear?
Old 08-10-2009, 09:40 AM
Fo by Fo's Avatar
32x11.5 whats offset/backspacing mean?
Old 08-10-2009, 09:41 AM
Fo by Fo's Avatar
Dunno, I should check that, good suggestion.
Old 08-10-2009, 12:31 PM
highonpottery's Avatar
seriously! looks like a 4x4 could almost fit between those sidewalls and the UCAs. i'm suggesting having a look at your wheel bearings as well - lots of pressure on those when your wheels stick out like that. also, what's up with that CV angle? is that pic taken while at full compression?
Old 08-10-2009, 12:35 PM
Ardent's Avatar
I'm guessing that you're talking to me as I'm the only one who posted the pics (I'm not the OP though...). 3 3/4" BS on those wheels but they're not "sticking out" that much, and yeah, that's at full compression and slight turn to driver(taken on the trail). I'm surprised you didn't mention that my shock was rubbing on my bumpstop bracket...
GreenLion
06-07-2021 10:49 AM
voiddweller
19
05-02-2016 09:10 PM
CordovaKid
07-06-2015 05:12 PM
paxanders
06-21-2015 06:29 AM
HBoss
12-20-2004 08:45 AM
Quick Reply: Loose steering, what parts should I replace
