Looking for a smoother ride
Old 07-07-2008, 10:28 AM
swerks's Avatar
I have a 86 4Runner that had the typical worn out rear leafs, so I installed new OME leafs in the rear and new OME torsion bars up front. I had newer stock length trekmaster shocks all around. my new suspension rode very rough, but I gave it several months to settle. I did need to crank the torsion bars a bit to level the truck some. I also removed one leaf from each stack but that changed the ride very little. I am not sure how to proceed?? I am contemplating ball joint spacers and possibly longer shocks any ideas??? and SAS is not an option.
Old 07-07-2008, 10:32 AM
CJM
CJM's Avatar
Softer shocks like monroes, uncrank the torsion bars, and lighter tires.
Old 07-07-2008, 10:35 AM
dirtoyboy's Avatar
How big are the OMES?
Old 07-07-2008, 12:18 PM
swerks's Avatar
rear leafs give me about 2in of lift. the bars are 23 mm I believe
Old 07-07-2008, 12:24 PM
swerks's Avatar
This is how its looking
Old 07-07-2008, 12:27 PM
904_runner's Avatar
if you put a bunch of weight in the back for a while won't that help the back settle a bit?
Old 07-07-2008, 12:36 PM
swerks's Avatar
Ive done that !
Old 07-07-2008, 01:10 PM
hurley842002's Avatar
While its not giving you the ride you want, It looks awesome. Perfect stance in my opinion. You may try using OME shocks, i've heard there shocks are softer and are made to work with there springs and make up for the rougher ride of the heavy duty springs, someone correct me if i'm wrong. I will be going with rear OME springs as soon as the budget allows.
Old 07-07-2008, 06:19 PM
CJM
CJM's Avatar
Which OME leafs and where did you get them is what I want to know, cause I havent seen OME leafs give that much lift before.
Old 07-07-2008, 07:04 PM
toyotanick's Avatar
the easiest way to get a smoother ride, but will hurt your offroad capabilities is to add weight to the vehicle. your vehicle does not weigh enough to compress the spring. the addition of a spare tire may even be enough.
Old 07-08-2008, 03:23 AM
swerks's Avatar
I have the spare in the bed in back
Old 07-08-2008, 03:32 AM
Alex 400's Avatar
see if they settle in a bit after driving around. if you got a place to put them through some articulation i would do it.
Old 07-08-2008, 03:54 AM
tulsa_97SR5's Avatar
Not really helping you, but curious which leaf you removed and what it did to the ride height. I ask because I have new OME springs all around on my 85 (currently not driveable) and it's sitting quite a bit higher than I really want.
Old 07-08-2008, 04:41 AM
dirtoyboy's Avatar
No kidding.....those leaves look really arched!
Do you have add a leafs? What size shackles are ya running?
Old 07-08-2008, 06:36 AM
swerks's Avatar
no addaleafs and stock shackles
Old 07-08-2008, 06:57 AM
swerks's Avatar
Here is a pick of my leafs and shocks
Old 07-08-2008, 07:03 AM
dirtoyboy's Avatar
Whats that leaf on the bottom? looks like an add a leaf/overload to me....see how its thicker than the other leaves
Old 07-08-2008, 07:13 AM
CJM
CJM's Avatar
Like I said, where did you get them from? All the places I have ever seen to order OME leaf packs state you may get 2" of lift or so max.. Thats a good 3 inches imho.
Old 07-08-2008, 08:02 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
That's an overload. Even factory leaf packs have them. In fact, factory packs even have that number of leafs.
Swerks...
Maybe it's just painted, but the shackle hanger looks new. Did you have new hangers installed?
Old 07-08-2008, 10:23 AM
swerks's Avatar
Parts were purchased form TRDparts4U and I did install new shackle hangers but they are stock length
Quick Reply: Looking for a smoother ride
