Looking for folks using SDS-EM4 on a 22re!
Howdy YotaTech,
I'm looking for folks out there using the SDS-EM4 system on the 22re. I have a few questions regarding some tuning parameters. Specifically:
Idle: How does your engine idle/ how have you programmed the SDS for idle?
Hot Starts: How does your engine fire when hot? Especially returning to idle after initially firing.
Knock sensor: Stock Toyota or Other? / Settings?
Optional electric cooling fan: Do you run one? How well does the SDS manage it?
Timing: Mostly curious what you run for the RPM/TIMING base curve. As well as advance in vacuum.
Thanks everyone who reads and or answers!
