looking for advice on 22RTE Repairs
Old 10-25-2007, 04:52 PM
AE86GTS's Avatar
How hard is it to rebuild the CT20 i found a good rebuild kit on e bay for under 100 bucks?
also should i upgrade to a ct26?
also how hard is it to get lifter ticks to go away?
i plan on trying to do all this work when i do the timing chain and metal guides
and what about inter coolers and trying to turn up the boost to like 8 or 10 maybe?
Old 10-26-2007, 02:35 PM
dcg9381's Avatar
There is a new forum on these motors in particular that might answer your questions:
http://www.22rte-trucks.com/simplemachinesforum/
If that rebuild kit is seals and some bearings, it's not worth $100. Besides, without knowing how to rebuild it - and reassemble it in proper orientation - and have a machine to dynamically balance it, you shouldn't try to rebuild it at home. Blaast performance in Canada - and a number of rebuilders in the USA can do it right for around $300, assuming it's in reasonable shape.
You can upgrade the a CT26 (supra version only) with a little work - you can also upgrade to a small T3 with an adapter - how either of these work with factory EFI, you'll have to ask on the above forum.
I ran without an IC for a while. The 22RE and 22RTE both have really high intake temps and an IC will make a big difference. I dropped about 70 degrees off my intake temps with a $30 intercooler.
Old 10-26-2007, 07:18 PM
87turbo's Avatar
lcengineering turbo kit
Garrett T3/T4 turbo
manifold adaptor
gaskets
custom oil lines
$1600 but the turbo is completely rebuildable easy to find parts for and WAY more reliable than ty ass CT20
time to bust out the credit card/
Old 10-27-2007, 12:56 PM
n4ynu1010's Avatar
Old 10-27-2007, 07:39 PM
Trumpfan's Avatar
Where did you end up putting the IC? I have AC and am stuck putting the IC up over the engine somewhere, what sensor did you use to measure intake temps?
Old 10-28-2007, 05:29 AM
dcg9381's Avatar
I mounted it behind the skid plate and built a scoop for it.
My intake temps are measured at the intake - I have a GM sensor, but you can use the stock sensor that's in the IAT.
wberry85
04-06-2018 08:45 AM
indawire
11-29-2015 05:05 AM
fabing455
09-07-2015 08:08 AM
viesail
09-05-2015 04:23 AM
DiggnDeep
09-03-2015 02:45 PM
Quick Reply: looking for advice on 22RTE Repairs
