| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
looking at 88 4runner with knock
#2 (permalink) |
sounds like it might've been a shoddy rebuild man... I think I would pass, unless he is willing to part with it CHEAP.
__________________
-Chris Tread Lightly! 04 Double Cab PreRunner. 3.4 - Auto 84 4Runner 4WD. 22R - 5 spd Lifted, Locked, 33x12.50 Disclaimer:My Photobucket is being revamped. If there are broken links, shoot me a PM. Thanks. ~Chris Great Toyota Tech |
#3 (permalink) |
Yeah,, I'm with Chris. Sounds like the rebuild was most likely not done right and has a rod knock (especially pass if it's a 3.0). If it was a really good deal and you had the money to gamble on it a bit maybe I'd do it but since you're limited on cash and need a DD I'd keep looking.
#4 (permalink) |
pass. if it was rebuilt 3 or 4 years ago and has been sitting with no fuel or anything, and you start it up and its knocking hard, then yeah its a VERY shoddy rebuild. though.... how sure are you that the oil in there isnt 3 or 4 years old too? a lot of people dont drain their fluids when they park stuff for a long time, and oil turns into a jelly... same with gas... i believe? correct me if im wrong anyone?
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22re, 1200 miles on the rebuild engine builder .268 cam pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread |
#5 (permalink) |
Thanks for the replies.
I got there and checked the oil first thing, it was clean, said he changed it a little while back. No metal evident in the oil when I checked it and it was new clean oil. Started it and ran it for a few minutes while priming with gas and checked the oil again, still looked good. light rust on front fenders and rear fenders, wants $700.00 for it. |
#6 (permalink) |
do a compression check and everything. find out whats wrong with the fuel system. if theres nethin wrong with it other than its been sitting and needs to be blown out, start at 300 and work your way up. when my mom bought her expedition a couple years ago, it had 67,000 miles on it and the dealer wanted 29k for it. i talked him down to 11k, since it needed new suspension, new exhaust, new paint on the tailgate, plus hell its an 01 and it had 67000 miles in a year. so yeah... start super low and work your way up. and if ur sellin sumthin, start high then work your way down. lol.
__________________
#7 (permalink) |
Thanks
I gots some thinkin to do. |
#8 (permalink) |
It could be it had to oil the entire motor for the first time in years , knocking not good , I probably would have opted to prime the oil pump good with starter (no fire at plugs) and then gave it a go , be nice if you didn't have the fuel problem but sounds like a fish story as far as what condition it is in or what has been done , does he have receipts of the work ??
Good Luck
__________________
Guy '91 ExCab Dlx Longbed/3VZE-Fast/Stock 2WD/5spd Manual '95 GMC Jimmy SLS 4WD/4.3L Vortech/Euro Susp and Motor Package/Tow Package F.A.I.T.H. Forsaking All I Trust HIM Matthew 19,20 : 19 I say again unto you,that if two of you shall agree on earth as touching anything they shall ask,it shall be done for them of my Father which is in Heaven 20 For where two or three are gathered in my Name,there Am I in the Midst of them |
#9 (permalink) |
So I passed on the 86 with a knock, and found an 88 with some light front end damage, water pump is seized but it starts and runs, no water in the oil, it has 176,000 on the ticker and new 31 tires. im pretty stoked to get started working on it this evening. Is the waterpump easy to change on these? is there write up somewhere? do I need to us toyota red coolant on the truck?
Oh it has the 3.0 or 3-slow as I have read on here. I will post pics in the following days. Thanks for the replies |
#10 (permalink) | |
Water Pump , Coolant
Quote:
If memory serves me right the water pump is behind timing cover and is kinda a pain but then you were probably going to put a new belt on anyway .
__________________
#11 (permalink) | |
Quote:
Um , I wasnt planning on changing the T-belt. Im new to these 4runners so I didnt really think of that (I have always had Landcruisers with the F engine, no timimg belt). Whats th interval for a T-belt change? The owner had it done once she said. Do have to remove the T-belt to replace the water pump? I should probably search. Last edited by tibbycruiser; 10-17-2007 at 01:52 PM. |
#12 (permalink) | |
Water Pump
Quote:
http://personal.utulsa.edu/~nathan-b...09waterpum.pdf
__________________
#13 (permalink) |
Water Pump
[quote=n4ynu1010;50642336]Check this link from the FSM and looks like Timing belt has to be removed , if it is over 30K on the belt I would change if it were me .
http://personal.utulsa.edu/~nathan-buchanan/93fsm/engine/109waterpum.pdf[/quote] And in case you don't have here is the online '93 that pretty much covers 88/89 to around '94 , two lists on the page link , first list you will see is for the 4 banger - scroll down a bit and you will see the same list for 3VZE 3.0 motor : http://personal.utulsa.edu/~nathan-buchanan/93fsm/
__________________
#14 (permalink) |
Thanks n4yn much appreciated.
#15 (permalink) |
Well, it looks like its the Fan bracket that locked up. I have been reading about this on here and thats what it is.
Dealership wants $800.00 for a new one with clutch and pulley. Salvage yard $40.00 |
#16 (permalink) |
__________________
#17 (permalink) |
LOL ..........$800 ROFL
__________________
#18 (permalink) | |
Quote:
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 95 4Runner Knock Sensor Help | Justice2318 | 86-95 Trucks & 4Runners | 6 | 03-10-2007 10:47 PM |
| 4Runner Knock | TBarnes | Newbie Tech Section | 10 | 12-04-2006 08:24 PM |
| Knock, knock from the power steering pump! | FSRBIKER | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 12-30-2004 07:23 PM |
| More info on 94 4Runner 3.0 with knock | Ted Bundy | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 06-06-2004 04:14 PM |
| knock knock? whos there? tranny? | joshik | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 03-02-2004 09:24 PM |
