a long last...
Old 02-01-2009, 12:57 PM
iamsuperbleeder's Avatar
at long last...
I installed my t-stat housing temp-probe mod this weekend
horrible camera-phone pics, I know... but there's not a whole lot to take pictures of really
and I just realised the thread title is missing a letter... it reads "a long last", it's suppose to say "at long last"... mod, please change?
Old 02-01-2009, 01:02 PM
Jay351's Avatar
Sweet! I got my guage pillar, now I need guages
Old 02-01-2009, 01:08 PM
if I had to do it again, I'd pony up the dough and get full electric gauges... it'll make the install a lot easier...
maybe I'll upgrade later on, but I just thought I'd throw that out there
Old 02-01-2009, 01:43 PM
scuba's Avatar
I would if I could......
Old 02-01-2009, 01:55 PM
Jay351's Avatar
Im defantly going electric. But i probibly won't be able to afford the autometer gauges I want ($200 a pop ). I will probibly go with a cheaper electric. Still not %100 on the last guage I want to run ( temp, oil pressure and.....?).
Old 02-01-2009, 02:40 PM
yeah, a lot of gauges are freek'n outrageously expensive for some reason... I don't get it...
Old 02-01-2009, 02:48 PM
874runnersr5's Avatar
oil temp?
Old 02-01-2009, 03:02 PM
BigBluePile's Avatar
Go with VDO gauges:
These are less the $30 a piece and work great! They're electrical too, but you have to buy senders seperately. Simple, effective and work great in your a-pillar pods.
Bleeder it looks great!!!!
Old 02-01-2009, 04:17 PM
you guys ever seen the guages where you pretty much design the guage on your computer with a usb cord? its insane haha, you can do so many things
Old 02-01-2009, 05:26 PM
Jay351's Avatar
Originally Posted by 874runnersr5
oil temp?
I dunno if I really need that.. Water temp should be good enough right?
Go with VDO gauges:
I kinda wanted full sweep guages... And the temp needs to be in celcius.. Im canadian I can't understand your funky temp measuring system..
Old 02-01-2009, 05:42 PM
Hayes's Avatar
go voltmeter. Monitor your charging system and know if there is a problem before you get totally drained.
I run volts, oil pressure and trans temp (auto trans). When I get to feeling like I need more than the stock temp gauge I can run another sensor through a dual switch and swap back and forth between trans temp and coolant temp.
Old 02-01-2009, 06:40 PM
Check here: http://www.egauges.com/VD2_main.asp
Like this:
Old 02-01-2009, 06:43 PM
Volt meters are pretty basic, but if you really want to see how your charging system is working use an ammeter.
Old 02-01-2009, 07:45 PM
89whitetoyota's Avatar
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
22r oil sending thread pitch is retarded, none of the adapters that come with sunpro, FAZE, or anything are a direct fit, apparently autometer has the right adapter? this is my hold up.
Old 02-01-2009, 07:48 PM
hmm good point, if i only had a turbo i could have a boost guage =(
Old 02-01-2009, 07:59 PM
annoyingrob's Avatar
Threadjack
Oil Pressure, Boost, and EGT. Not pictured, on the other side of the steering wheel are water temp, and fuel pressure. All electronic peak and hold
Old 02-01-2009, 08:19 PM
Jay351's Avatar
crazy lookin interior!
Old 02-01-2009, 09:32 PM
seriously... what am I looking at???
Old 02-01-2009, 09:36 PM
myyota's Avatar
not sure what it is, but i would say its right hand drive, by the picture.
Old 02-01-2009, 09:38 PM
maybe the Supra in his sig???
Quick Reply: a long last...
