| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
long day of front end noise..
__________________
94 Ext. cab 22re Aussied, 4.88's, SAS,ed, FLATBED, Old Man Emu rear leafs w/TG 5.5" shackles, TG sliders, LC Header, Marlin super HD clutch, 32's- Swamper TSL's- RC rims, Badland Bumper, lifted, lighted, LED'ed, Warned, alternatored (LC High ouput), Hammed, gusseted, trussed, etc, etc... My build thread http://www.yotatech.com/f152/great-w...ck-sas-164531/ My Flatbed build thread http://www.yotatech.com/f88/toyospea...-build-191787/ |
#2 (permalink) |
find out for sure, look in the fsm to find out how to test the ball joints.
how bad is the bump to make the sound? does it do it even with the slightest bump? if so, have someone bounce up and down on the front end an have a look or listen to see or hear where its comming from
__________________
Mike 1990 4runner: 3.4 swapped, 5-speed, sas'd, Rear leaf swap, Locked, 5.29's, 39.5" iroks on Beadlocks, Armor'd Longfields, Duals coming soon: My build thread http://www.yotatech.com/f152/904_run...thread-158746/ http://www.treadlightly.org/ http://www.pirate4x4.com/tech/billav...ery/index.html |
#3 (permalink) | |
Quote:
Other than the ball joints what else could it be?? thanks
__________________
#4 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
well,we know it's making noise, but can you be a tad more specific about when it makes noise, like a bump up, or a pothole down, or... more often turning left or right....
is your swaybar still connected and are the bushings on the frame good?
__________________
Quote:
Insomnia: it's a way of life.
#5 (permalink) | |
Quote:
It makes noise on the bump down . the swaybar is still there. I just replaced the idler arm and pitman arm. It makes the noise going left or right but mostly going straight. If I hit even a small pot hole or small rock it bangs like hell. I can feel it through my whole body.
__________________
#6 (permalink) |
Check all your control arm bushings. I had a bad rattle once that turned out to be a blown upper control arm bushing causing the t-bar to actually hit the body on bumps.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Front end noise...help, thanks | Swissdrums | 86-95 Trucks & 4Runners | 9 | 04-05-2006 01:20 PM |
| non starting woes........ end of long day. | needayota | Maintenance & Repair Archives | 4 | 05-08-2005 06:55 PM |
| Front end noise | slustan | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 12-17-2004 08:00 PM |
| Front End Noise | Cebby | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 02-09-2004 04:19 PM |
| front end noise- HELP!! | Peter Sween | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 09-10-2002 09:36 AM |
