Lockouts
Old 02-06-2014, 04:13 AM
Crazy_Guy97's Avatar
Lockouts
Is there a certain way the lockouts go on the cv joint?
Old 02-06-2014, 06:04 AM
scuba's Avatar
No. The gear needs to spline onto it, then you need to line up the dowel pins, but that's about it.
rattlewagon's Avatar
They go over the splines. Lining up the 2 small dowel pins.
Your question is pretty vague. What problems are you running in to?
Old 02-06-2014, 06:16 AM
daved5150's Avatar
The locking hub or lockout's splined ring slides over the splined axle end of the CV shaft. The lock out body itself is bolted to the hub. Are you having some sort of problem or converting to lockouts?
Old 02-07-2014, 04:12 AM
The problem is that when I which it to lock it dont go all the way.Another question is the cv joint post spin on free or lock.
Old 02-07-2014, 04:23 AM
If you lock and unlock the hub in your hand (not on the truck) does the gear move all the way? Are they dirty? Do they need a rebuild? Broken springs?
Pictures would help us.
Old 02-07-2014, 04:32 AM
They move fine now.No broken springs . Its put back together now it went like it was post to.Took all day to put a cv joint in and a lockout on.
Old 02-07-2014, 05:50 AM
I attached a hub diagram, shows you how to assemble them.
mudfun
12-27-2010 04:26 PM
ORS
11-17-2009 01:21 PM
rockrunner2600
12-08-2008 04:19 PM
Turd Ferguson
05-30-2007 05:42 AM
Quick Reply: Lockouts
