Location of temp senders(i've searched)
Old 07-03-2009, 07:49 AM
dstn2bdoa's Avatar
My Temp gauge has been going to normal temp immediately after cold start, then never moving. This morning on my way to work, it just quit.
I bought a temp sender but it didn't match what I thought was the the one I need to replace.
The first pic shows what I thought was the one, in between the plenum and valve cover, with blue wire clip.
The second pic is what I had hear might be the one for the ECU, Not sure if it is the brown or green? Just under the TB and to the right.
I have an transplanted SR5 cluster, in a 88 P\U 22re.
I need to get this done today, before all the stores close for the fourth.
Thanks
Attached Thumbnails Location of temp senders(i've searched)-tsender2.jpg   Location of temp senders(i've searched)-tsender.jpg
Old 07-03-2009, 07:53 AM
BigBluePile's Avatar
Yes the one by the TB is for the ECU, the one between the plenum and valve cover is for the gauge.
Old 07-03-2009, 08:42 AM
dstn2bdoa's Avatar
Thanks, but for the record, the one that does the ECU, is it the brown or green?
Old 07-03-2009, 11:44 AM
dstn2bdoa's Avatar
I did a better search and found my answer. The sensor that goes to the ECU is the one on the right, and its green.
I bought a new temp sensor for the ecu. I figured I'd change that also. The one I bought from Autozone was maroon like the cold start switch next to it. I realize that the aftermarket doesn't' necessarily care about colors, but I thought that I'd just ask in case someone has done this recently.
Is this the right sensor?
Duralast SU405
Old 02-06-2010, 05:43 PM
boonville's Avatar
Did that one work for you? Just picked up the same one and notice it has two teeth on it whereas my orginal has one only.
oldirtydirt
02-23-2020 09:30 AM
Nickyodaman
07-27-2015 12:13 AM
Jeffreynmandy
07-18-2015 08:26 AM
Poncho0206
07-10-2015 06:21 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Location of temp senders(i've searched)
