a little help please... where is the ac compressor located at.. pics inside
Old 08-08-2007, 03:32 PM
BLUE BEAST's Avatar
ok yotatechs... never saw an ac compressor so i dont have a clue on how it looks like... i just bought a 1992 toyota pickup v6 4wd... the owner i bought it from had a rebuilt motor put in... when i was test driving the car in the heat i turned the a/c on... nothing but hot air... was told that it needs to be recharged... called around got qoutes around 200 bucks... he also told me that if recharge fails he will pay to get it fix... he puts it on paper and signs it... the seller was a co worker... but yea... back to the compressor... is there a way to see if the compressor works or not? and where is the inlet to rechage it.. im not doing the recharge... just wondering where things are... heres the pics...
it will be great if someone can use microsoft paint to circle the compressor and inlet where you charge it...
<src img="http://i92.photobucket.com/albums/l23/whorebox250/THE%20DOUBLE%20B/IMG_2764.jpg?t=1186615712">
or is this it under the engine?
pic of truck...has a 7" lift
thanks folks
Old 08-08-2007, 03:39 PM
jcfb's Avatar
Sorry, not seeing the inlet to charge real clearly on the other picture. It will be on the passenger side of the engine bay, so take a closer picture over there.
Old 08-08-2007, 04:01 PM
BLUE BEAST's Avatar
more pic of pass side...
Old 08-08-2007, 04:02 PM
BLUE BEAST's Avatar
my files are too big huh... is that why its not showing on the post?
Old 08-08-2007, 04:09 PM
Paul H.'s Avatar
jcfb has it. Look for a schrader valve on top, left hand side. thats where it gets recharged.
Old 08-08-2007, 04:23 PM
BLUE BEAST's Avatar
i think i found it... so this is the r 12 system huh... i just called a local shop wants 249 to convert it to 134... good bad?
Old 08-08-2007, 06:53 PM
longhungsilver's Avatar
depends... is that price including new refridgerant?? If not are they going to modify any lines?? i know sum ppl say that you need different lines to hold the r134a or else itll leak out slowly
Old 08-08-2007, 07:14 PM
runethechamp's Avatar
My local dealer was not worried about this. Their retrofit was only to flush out the old system, change the fittings, and pump in R134a. Haven't done the mod yet though.
toofly1999
07-25-2015 07:09 PM
94whiterunner
07-12-2015 07:15 PM
crashburnoveride
07-10-2015 06:39 AM
skoti89
07-08-2015 12:05 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: a little help please... where is the ac compressor located at.. pics inside
