Limited Slip Question
Hey guys I dont wheel a lot so dont make fun of me just had a diff question. WHen i bought my runner about 10 months ago the PO said it had a Detroit trutrac diff. I figured it was similar to a limited slip.. Sure enough both rear tires spin the same direction when i have the rear jacked up...but i can grab one tire (and stop it from moving) while spinning the other tire.. to me this means its not limited slip or perhaps the clutches are worn out?? if i burn out in gravel it leaves 2 tire tracks..
So am i just wrong in what a detroit trutrack is? or are my clutches worn out??
thanks guys
thanks guys
google it
At first I didnt have an answer for ya, but then i tried a....
...GOOGLE SEARCH!
im new around here too, but simple questions can be answered easy enough by some quick research instead of pluggin up the forums
it is a limited slip, btw
...GOOGLE SEARCH!
Sounds like a normal TrueTrac (a torque sensing limited slip diff):
- http://www.4crawler.com/4x4/TrueTrac.shtml
And you can lock them up with the brake biasing technique.
jack it up and pull the E brake while the tires are spinning to load it down.... then try stopping a tire while it spins . I use the E brake trick all the time on my TruTrac in fact its never let me down so I don't see any need to replace it with a full Detroit..
thanks for the responses guys
FS[PacNorWest]: Parting 2000 4Runner Limited 4WD Marysville, WA
DeathCougar
04-01-2018 11:29 PM
crammit442
7
11-29-2017 12:30 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
