Lights on but wont crank
I have a weird problem. A 94 Camry that wont crank. It used to start about every other time you turn the key. But now it just wont crank over. I have since replaced battery (w/ new). Had the starter checked out at shop. Replaced the starter relay. Cleaned some connections and still no crank. When I turn the key to start, the lights dim but no starter noice, not even clicking. UGH !
Any ideas ? I have a 4Runner so dont beat me up for posting a Camry ha ha, (Camry for sale, buying another 4Runner)
Still hunting
I dont have a way of checking voltage at starter but the wire connection from ignition is a little loose. I'll correct that and I also got shocked a couple of times by the door. Weird. I will be checking the ground wires tomorrow. Cleaned all the cable connections. Oh and its an automatic.
Concur with above.
Because you can't reach it? Or because you don't have a multimeter? No excuse for the latter. http://www.harborfreight.com/7-funct...ter-90899.html
You have an electrical problem. It's diagnosed with a multimeter. You can tighten loose wires and grounding bolts, but it will only be luck if you bump into the actual problem.
4rollin
12-05-2015 07:17 PM
