Lifts.....Tires
Lifts.....Tires
Im looking for a cheap but Quality lift for my 93 Pickup.
Also a place to get it put on. any good places around me.
An i want new off road tires but im not looking to spend 1000 bucks on um
what is the best bang for the buck
X2.
Search for it, somebody just did a whole thread about all the possible lifts available.
theres ball joint spacers.
body lifts.
bracket lifts
torsion bar lift
Sas
etc. Its all up to you.
body lifts.
bracket lifts
torsion bar lift
Sas
Once again, all personal opinion.
Some say they don't like body lifts for what ever reason they have.
others like body lifts because it allows to run bigger tires, you can get closer to a flat belly, and you don't weaken the ifs by changing the angles on the steering components.
Your best bet right now is to try the search function and be prepared for a lot of reading. But in the mean time.
For inexpensive tires go to treadwright.com.
For a mild lift that you can do in the driveway I recommend ball joint spacers and either an add-a-leaf (if you have leaves), adding a coil spring helper (again if you have leaves) or coil buckets (if your truck has coils).
Oh and if you're planning on going with bigger tires start thinking about gears to match..... and perhaps a locker or two........
Welcome to the addiction.
Least expensive way?
Install 33x10.50 on your stock rims, bolt em on and drive away. This method also eliminates all the downsides of a lift - higher center of gravity, increased steering component wear, etc.
Thanks dude that was what i was looking for. I just cant afford a lift right now an i have a/t tires but i want something more aggressive. If i do go in this direction, what gears would i have to think about. i mean thats a pretty big job isint it
Your COG goes up the most with a tire lift. Your lifting everything including the axles up 1" if you from 31" to 33" tires. Mind you, it that lifting this way is the most effective in terms of performance gains.
how can I put 33's under my 88 4runner without having to beat on the truck to make the tires not hit the fender when I have the steering wheel turned all the way to the side and I hit a bump?
the truck came with 28" tires stock
^ well abe, its real simple...
I figured you have been round here enough to know this already. but...
Just let them rub! After a while, your fenders will be formed a bit more, and will no longer interfere. Best part is, its free!!!!!!!!!!
dude. it is a well known fact that says 33's can fit with no lift. does your brothers truck have different rims because that will make them rub. 33x10.50 (skinny) will fit on stock rims with only slight massaging of the fender wells.
as for lift ideers:
its kind of like you can get quality or low cost.
imo cheapes lift you could do without sacraficing the strength of yer rig would be this:
2" bj spacers
an inch or less of tbar if you want it
rear 3" aal
shackles if you want em
for tires i would recomend bfg muds or a/t's they are a very nice tire and easy on the wallet
If you cant make 33's rub you arent trying hard enough
235/75/15's on my truck, they nearly touch on the rear. Front will take 33's no problem though because it is really hard to stuff the torsion bar setup into the wheel well without lifting a tire.
talk to TC and tell him that he doesn't push is stock truck with 33's hard enough. The key is the 10.50 width.
