Let's talk about 22RE swapping a VAFM from Supra's and Cressida's
Ok I searched and found some info but not the answer for sure. I read that an 82 Supra VAFM is a bolt on for the 22RE. Now the question I want to know is that will the Cressida VAFM work? It is the same engine, 5MGE which is in the 82. Now I recently just got two VAFM's from some Cressida's, one being an 84 the other the 85. Now the 85 is definitely bigger than the 84 but both had the same motor the 5MGE. Now I compared them to the 22RE and they are both are bigger. Now what I want to know is are both of these a plug and play? I have some part numbers:
1984: Toyota# 22250-43140
Nippon-Denso# 197100-2320
1985: Toyota# 22250-43230
Nippon-Denso# 197100-3150
James
James
Ok cool. I just remembered my Snap-On Vantage PGM has the wiring read outs on it. I'am going to dig it up and see if it goes down that low of a year for the specs.
James
James
Any 79-82 Supra will be plug and play. I found other VAFM's that were plug and play but I do not know the sizes. For example and 83 Camry has the same harness pinouts and so do the Van 3YE's but again I do not know the sizes. Actually others will work but they have a 5v ECM reference not like the 22RE that has an 8v reference. I do not know if the 5 or 8v is coming out of the meter when plugged in or it is going into the meter when plugged in. If it is going into the meter then all you would need is a dropping resistor to get it to work.
The Cressida VAFM's that I have is not a direct plug and play. Here is what I mean. Now this is looking at the BACK of the connector that plugs into the VAFM from left to right: 1-2-3-4-5-6-7
All 83-95 22RE and TURBO, 79-82 SUPRA 5MGE, 81-82 Cressida 5MGE, 84-89 3YE Van, 85-89 4AGE MR2 non S/C, 85-91 4AGE Corolla, 83-86 2SE Camry, 83-84 4KE Starlet
1= Fuel pump switch
2= Fuel pump switch
3= ECM (-)
4= IGN (+)
5= ECM (+8v)
6= VAF signal
7= IAT signal
83/84 Cressida with the 5MGE
1= Fuel pump switch
2= Fuel pump switch
3= ECM (-)
4= ECM (+5v)
5 Not used
6= VAF signal
7= IAT signal
83/84 Supra 5MGE
1= Fuel pump switch
2= Fuel pump switch
3= ECM (-)
4= ECM (+5v)
5= ECM (-)
6= VAF signal
7= IAT signal
85/86 Cressida, 85 Supra 5MGE, 86-92 7MGE non-turbo Supra, 87-92 Cressida, 88-95 3VZE trucks(T100 as well), 88-92 3FE Land Cruiser, 93-94 1FZ-FE Land Cruiser, 91-95 2TZFE Previa non-S/C, 86-89 3SGE Celica non-turbo & turbo, 88-91 2VZFE Camry, 92-93 3VZFE Camry, 90-91 2VZFE Lexus ES250, 92-93 3VZFE Lexus ES300
1= Fuel pump switch
2= Fuel pump switch
3 Not used
4= ECM/PCM (+5v)
5= ECM/PCM (-)
6= VAF signal
7= IAT signal
I think I got them all. These listed above are for the vane air flow meters (VAFM) only!
James
1= Fuel pump switch
2= Fuel pump switch
3= ECM (-)
4= IGN (+)
5= ECM (+8v)
6= VAF signal
7= IAT signal
1= Fuel pump switch
2= Fuel pump switch
3= ECM (-)
4= ECM (+5v)
5 Not used
6= VAF signal
7= IAT signal
83/84 Supra 5MGE
1= Fuel pump switch
2= Fuel pump switch
3= ECM (-)
4= ECM (+5v)
5= ECM (-)
6= VAF signal
7= IAT signal
1= Fuel pump switch
2= Fuel pump switch
3 Not used
4= ECM/PCM (+5v)
5= ECM/PCM (-)
6= VAF signal
7= IAT signal
James
James
James
James
i just installed mine tonight... i guess it has the intake silencer removed, and it sounds AWESOME! GREAT improvement in performance too... i noticed a BIG difference in climbing hills, i can actually ACCELERATE going UPHILL. still not a V8, but hey, a 22RE CLIMBING a hill at 60-70MPH! i was like, HOLY SHIKES!
Good thread , i'll give it a try with the one I have here . I will update with pics.
heres some more info for ya
82 Supra afm part number
22250-43110
197100-3020
afm pinout 82 ONLY !!!
22250-43110
197100-3020
so if i get a vafm from 85/86 Cressida, 85 Supra 5MGE, 86-92 7MGE non-turbo Supra it would be a direct bolt on to a 3vze???? and for me to get any performance out of it, it would have to be out of a supra or cressida?????
James
