leaky transfercase
Old 03-31-2008, 08:34 PM
SR5
SR5's Avatar
leaky transfercase
as the title says my transfercase has been leaking, and cant figure out were or why.
it seems to be mostly on the right side (looking from back of car forward) but not in any specific location or spot. it leeks without me using four wheel drive
when i checked it was a quart and a half low, after i filled it up i sprayed the out side of it so that it was bone dry. in about half month the whole thing was wet again.
the only thing i can think of is that it dosent have gaskets, it is sealed with silicone, and i think it might of gotten old and cracked,
what do you guys think?
Old 03-31-2008, 08:40 PM
89silverpu's Avatar
Take it apart and put some gray RTV gasket material on it for a gasket, or get a gasket material sheet and make your own
Old 10-09-2012, 06:10 PM
1990yotapickup's Avatar
i have the same problem mine is a 90 toyota pickup with 120,000 miles and i cant seem to find where the leak is coming from it has never leaked? do you know how much the gasket material sheets are? any advice will be helpful. thanks.
1uzRunner
63
11-10-2018 03:58 PM
shooter86314
01-07-2016 07:05 AM
Jcrawl94
10
10-24-2015 04:34 PM
yoterr
09-15-2015 06:26 AM
hoosierhog
09-22-2005 08:28 AM
Quick Reply: leaky transfercase
