leaky 22re please help
hey my truck just started leaking savagley from the front of the motor like half quart to a quart an hour know the timing chain covers are junk and or what seals could cause this up front or any solutions...
thanks
thanks
Might want to look at the front crank seal. Is it leaking high on the block or low? Oil pump housing could be leaking. Either way, it sounds like you are going to get to play with the famous front crank pulley bolt.
don't be surprized when the new front seal you buy is not the same thickness as the one you take out. I bought one from the dealership and it was about 1/2 as thick as the old one. Seems to work though and it was the proper part number. I triple checked.
