Leaking Coolant from Rear of engine, Firewall area?
I have a 22r carbureted 2wd truck that has been running great. Today I pull into work and smell some anti-freeze. I look down and there is a pretty good puddle and a steady drip, drip, drip coming from the firewall area. Nothing visible up top from a quick glance. When I slid under I could see the bellhousing was pretty wet and it was dripping off the trans.
I know its hard to diagnos without more info...but, I am hoping someone can give me a couple pointers on what to check out when I get home tonight. Maybe its a heater hose or something? Any help is appreciated. I really haven't gotten a chance to look at it very close yet.
Thanks Scott.
Thanks Scott.
Yea, The time and pain in the a@@ is right. I'm about due to pull this thing in and check it out. Pretty much every fluid is seeping out at some place or another, now coolant is added to that list. I have a very leaky PS line someplace. Looks like it is coming out the steering box itself.
Thanks for all the Tech advice. I think I will just drive the '92 until next week when I have time to check it all out. Nice having two junkers! (as long as one is going good) -SR2
[COLOR=#00ffff]
Is this the 4-5" long C shaped guy that is seriously hard to attach, behind the engine? Mine is old and leaking but i didn't know what the hell it was to replace it, and i think the last shop that looked at it cut a bunch off and reattached it (poorly) so it doesn't look anything like any of the replacement hoses...
First guess: the little horseshoe-shaped water bypass hose under the intake plenum.
basically, yes. I had the same stupid problem on my 3vze. MF'er to get to, but if you so much as take it off for inspection there is absolutely no reason to put the same piece back on! What lazy morons. That should have been 1 hour of mechanic's labor (countless time and skinned knuckles for the layman, honestly, its a genuine PITA) and a $10-$25 hose depending on where you are. You have to get a pre-bent hose because otherwise it will crimp in the middle of the sharp 180 degree bend and thus be useless. Kick said mechanic in the testicles for their shoddy work and never pay them money again. Look for ASE certified on the wall, if they don't have it, don't go there. If they do, they should stand by the quality of work and honestly shouldnt put the same rotten old hose back on by principal. Good luck!
My hose with lighter for scale:
Pinched where the pinhole is:
thing with that little horseshoe is I wouldn't think it to leak underneath the firewall as much as directly underneath the intake manifold onto the main crossmember on the passenger side. If its really coming out the bottom right near the firewall, I would check out those hoses along the firewall as there are plenty of culprits along there to leak as well.
I fixed the powers teering pressure hose, so now it does not leak PS fluid. I filled the coolant and started to diagnose the coolant leak and the damn thing would not leak a drop. I have been driving it now for 3 weeks and not a drop of coolant. I am guessing it will probably come back, but for now I will drive it locally as is and visit here when the leak persists. Thanks for all the heads up on the little "horse shoe" hose. _scott
Thanks NYC, that is the same damn hose. Now that i see another one, they definitely put the old one back on with a new clamp...FAIL. doing it myself from now on, seems like the only way to know it's done right. I reclamped the loose end, then the other end started leaking, prolly from bending it around to get a clamp on a 20 year old hose!
now, to find a new one for less than $30...
Sorry for the crappy diag. It's that U shaped hose up in the back, part info for 3vze is HOSE, WATER BY-PASS, NO.3 (good call Rabbit!)
part # 16267-65011
thanks y'all!
voiddweller
19
05-02-2016 09:10 PM
jennygirl
11-17-2015 11:24 AM
cchinny
06-25-2015 08:11 PM
