| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
leak from water pump gasket ,water pump
#2 (permalink) |
Water pump and t-stat should only take a few hours to do. However, that can go out the door rather quickly.
What motor? I'd take your dad's advise and do the pump.
__________________
Anthony 93 ZJ - Stockish (HP D60 Front, 14 Bolt Rear, 231/D300 Crawl Box...awaiting 40" tires) Ballistic Crap Missile ILikeMud.net Mallcrawlin.com SOTRA |
#3 (permalink) |
One day, yes replace all if you can. It is a good time to check for your timing belt while you're in there, need to remove it to pull and install the water pump. If you are replacing the timing belt you giong to have alot more work done.
![]() The water pump is on the middle were the belt run through it.
__________________
My Rig - 1992 TOYOTA 4RUNNER, 3VZE V6, R150 5 Speed Transmission (5 Speed Swap, running on AUTO ECU & Wire Harness) 4x4, ( 225,500 miles ) all bonestock. Replace HG at 215,000 miles ( MLS HG). 1992 Toyota 4runner V6 A/T ECU/ECM for sale, part # 89661-35770, asking price at $100.00 USD. Free Shipping in the US. |
#4 (permalink) |
i was thinking just let some of the nuckle head do it at midas cause it will be a pain in the ass , that picture is from the 4 cly right , on my v-6 its a bitch to get too, my dad thinks alll i need is a gasket , and he said since we down there rpalce the water pump , gasket , thermostat, and maybe the timeing belt.
#5 (permalink) | |
Quote:
#6 (permalink) |
Holy Cow! Don't let Midas touch it!
That pic is the V-6, after all the outer stuff has been removed and yes, it is a PITA to get to. I'd suggest replacing it all while you're in there, to include the timing belt.
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap 3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/ |
#7 (permalink) |
midas lol the only reason i say them is cause i no the boss and he is my good bud on my old paintball team , but i think i may do it and save some money, i need my truck to run cause i wanna ride down the bullyvard here in myrtle beach, sc lol cuase it summer and i need it to stop freaking leaking.
its leaking from the gasket seal, almost 100% that the problem that little 3 doller gasket. Last edited by dcmbsc; 06-11-2007 at 08:47 PM. |
#8 (permalink) |
water pump R and R write up
Does anyone have a step by step water pump R and R for a so-so DIY'r? Mine is leaking and I have torn every thing down but have not pulled the timing belt yet. It looks pretty simple except for putting the timing belt back on correctly. A write up with pics sure would help.
#9 (permalink) |
this might help
http://www.4x4wire.com/toyota/maintenance/timing_belt/ its the 3.4l (5vze) but probably very similar to 3.0 (3vze)?
__________________
1987 Pickup, single cab, 22R, new head, 260 cam TG 3" SAS, rear disc brakes, chromoly rear axles, Chromoly Birfs, Tcase brake, 37x12.50R15 MT/Rs, 5.29 gears, rear Aussie Locker, front Detroit Truetrac. |
#10 (permalink) | |
Quote:
I think there's a sticky at the top of the page with links or go to a public library that has ALLDATA access? OR shell out the $100 for the manual - its worth every penny and you'll make it back in savings in not time. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wierd water pump leak? | slosurfer | 86-95 Trucks & 4Runners | 9 | 04-03-2007 09:10 PM |
| 3.4 Water Pump - what gasket to use? | ohio4runner4x4 | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 02-23-2007 03:19 PM |
| antifreeze leak. I'm thinking the water pump... | Charger92 | 86-95 Trucks & 4Runners | 12 | 10-18-2006 02:48 PM |
| Proper water pump gasket material/installation? | VA_Yotaman | 86-95 Trucks & 4Runners | 16 | 03-30-2006 05:50 PM |
| Water pump gasket? | vegaskurt | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 11-29-2005 05:02 PM |
