Leak problems.
Leak problems.
I have a 89 sr5 4x4 4cyl 2.4l and it has an engine leak... big suprise, anyway it was leaking really bad out of the rocker arm cover so i replaced that gasket and it slowed it down concideribaly (or however you spell that). but its still leaking a little bit and i cant tell where its coming from, any 1 had that problem, or who knows how to fix it?
thanks.
thanks.
like said above, and i would also get some good degreaser or cleaner (purple power is my choice) and spray her down real good let it do its thing for a couple min then power wash or rinse away, that way you might be able to pin point the leak a lil better, plus it just looks good
thanks, but i allready did all of that, so i'm thinkin its probably the head gasket, and if thats the case i think ill probably just check the oil often and dump some in when needed
lol i think so, i just bought the truck and have been workin on it ever since, if they are 4.10's there not that bad with 35"s...im gonn have to take out the third to get it welded anyway so im gonna count the teeth then
oh yeah and if you still cant find the leak, take some pics of it where you think its coming from and around and maybe some 1 can point it out for ya? worth a chance
yeah, so i just gave it a spit shine and i still cant tell where the leak is coming from... well at least that means its a slow leak, anyway is there a certian gasket at the front of the motor that normally leaks? (by front i mean nearest the radiator).
the1998sr5
15
07-14-2020 08:35 PM
skoti89
09-11-2015 07:46 AM
FS[PacNorWest]: IFS Locking Hubs $110 Shipped
A2theK
09-04-2015 03:16 PM
Avenged
07-09-2015 07:55 AM
