| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#26 (permalink) | ||||||
#27 (permalink) |
^^Agreed^^
With the turbo technology thats out there, you can pull some big numbers on little displacement as long as you have the bottom end to support. That little quote "There is no replacement for displacement!" that all the old timers use, doesn't totally apply so much anymore. I could have safely pulled 300awhp out of my little 2.0 suby for a little under $3k. I think Abe mentioned earlier, that is a conservative tune on behalf of LCE, and they could pull quite a bit more from that set up. I would give them a call before you totally write them off. Its good stuff for sure.
__________________
07 FJ, 6 speed 84 4Runner Last edited by stagger_lee; 12-22-2008 at 07:01 PM. |
#28 (permalink) | |
Quote:
I've never owned a turbo engine... what are you getting at ?
__________________
Screw you guys I'm goin to TTORA |
#29 (permalink) | |
Quote:
I know people pushing 600hp out of stock block honda 4-bangers with forged pistons and billet H-beam rods. With sleeves, there are some people pushing over 800hp. But remember this is only peak numbers and the torque curves on these engines are walls, flat until 3-4k then they shoot up a few hundred ft lbs in under 1k rpms. I'd say if you want an engine that won't break and is very reliable, buy the LCE engine. Its brand new, proven to run at 200hp. you'd be surprised at how fast 200hp feels in a truck/4Runner too, especially since stock we barely put out 100 to the wheels. Give em a call and ask them what kind of engine management they use and if its possible for you to modify the maps aftermarket or not. If its possible then upgrading it will be a lot cheaper. |
#30 (permalink) | |||
Quote:
Quote:
Its a 22r series engine, which means it has 2.2L of displacement. Torque/hp curves are much more important when actually racing/tuning then they are some peak numbers on paper. Go ahead and put in an engine with no torque and see how it moves below 3000 rpm. Torque is also important for trucks because they are heavy and are meant to be used offroading and towing where torque is key. Sport trucks are great and have their place, but 4X4's should be used for that, and not drag racing. Quote:
__________________
1996 4Runner. Revos, tundra brakes, 5" deckplate, ISR, inverter, addco sway bars, marlin 1200lb clutch. More to come! |
#31 (permalink) |
Don't want to get into this much but seaofnames, you gotta understand that 22R doesn't mean R series 2.2L. It is a 2.4L engine. The 20R was the 2.2L. Don't know why but that is what they are. Just thought I'd clear that up for ya.
#32 (permalink) | |
Quote:
The 22RE, is a 2.4L. And my truck, an 88 22RE, standard cab, short bed, 2WD...is probably lighter than modern day cars. I'll be more worried about putting the power to the ground more than I will about how much torque I can make. The stock motor would spin my tires now, and I think it has what, 110 ft lbs? With a build motor, it's going to put out more than that, and if it's spinning the tires NOW, well, you can put the rest of that sentence together. |
#33 (permalink) |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
Interesting point...
... getting the power you have to the ground before worrying about how much power there actually is.... I've seen people with VW's take Hemi's in an 1/8 mile. I've beat a turbo'd 5sp up to 100 miles per hour in my ... equqivalent automatic ... chrysler 2.2L turbo. I've seen stock Buicks take Corvette's... anyone remember the GNx? and now we have a 2.4L... I've seen 2.0L with 200 HP.... one thing to consider... put that subaru in a tug of war with your toyota... need I say more?
#34 (permalink) |
whoops.
#35 (permalink) |
If I remember correctly, the 20 and 22 have absolutely nothing to do with the displacement. 20R is the 20th iteration of the R series engine and 22R(E) was the 22nd iteration of the R series engine. 22R is a carb'd engine and the 22RE was fuel injected.
__________________
Obama is an acronym. OBAMA = One Big Ass Mistake, America |
#36 (permalink) |
GNX FTW !!!
__________________
#37 (permalink) | |
Quote:
Sorry to everyone about the displacement thing, my bad.
__________________
#38 (permalink) | |
X2 for the 3.4. Better yet, swap the 1KZT-E into it and you'll have the coolest toyota on this side of the pond. That's what I would have done if I had 6K to spend on a new motor/Swap.
Quote:
Cheers Dave
__________________
Project 4Rescue: 89 Gen1 22RE 5spd 4Runner...Marlin DOM rear bumper, OME rear/ BJ spacer front, OME shocks all around. Lucas Pro series HD clutch: DONE!!! BRAND SPANKIN NEW 22RE DONE!!!!! Firefighters: Cause somebody's got to step up and do it... RIP: Charles Edward DelaForest: Born Sept 78 - Murdered May 05 I miss you Brother |
#39 (permalink) | |
Quote:
EDIT: All this talk about different motors is completely irrelevent, so what if a FHI Boxer Motor can make 500hp... it's a different motor that was designed to take that power load and flow enough air to make those numbers. A motor like the 22RE is a long stroke motor that frankly was not meant to spool up to 7K and make 400horse. Is it stong enough??? Yes, absolutely, but it was designed to be a tourquey motor, not a race engine. The money I spent to take my 1.8L 8V VW motor up to over the 200hp at the wheels (206) mark was un-real. But with all that money came high quality parts and added longevity so... There are all kinds of motors with all kinds of displacements and designs, but not all of them will do the same thing. A motor is an air pump. The faster and more efficently you can get air in and out determines your power. Everything else just modifies your powerband or your Torque curve. With that in mind, have at it. Cheers Dave
__________________
Project 4Rescue: 89 Gen1 22RE 5spd 4Runner...Marlin DOM rear bumper, OME rear/ BJ spacer front, OME shocks all around. Lucas Pro series HD clutch: DONE!!! BRAND SPANKIN NEW 22RE DONE!!!!! Firefighters: Cause somebody's got to step up and do it... RIP: Charles Edward DelaForest: Born Sept 78 - Murdered May 05 I miss you Brother Last edited by Diesel_Freak; 12-24-2008 at 11:59 AM. |
#40 (permalink) | |
theres no replacement for displacement.
__________________
91 Toyota "built not bought" Quote:
#41 (permalink) |
#42 (permalink) |
__________________
#43 (permalink) | |
Quote:
__________________
07 FJ, 6 speed 84 4Runner Last edited by stagger_lee; 12-24-2008 at 02:25 PM. |
#44 (permalink) | |
lol, ok so you turbo your 4banger. then i put a blower on my big block
![]() the point is you can do all the mods you want to a 4cyl, and an equally built v8 is gonna have more power. you don't see a 4banger racing in top fuel do you?
__________________
#45 (permalink) |
I think he just wants to pull decent numbers on a 4 banger, not run high 4 sec 1/4s in his yote.
So...LCE, huh? NIce. |
#46 (permalink) | |
Quote:
Yes sir, VW's are known for being "real" performance vehicles. Front Wheel Drive is also known for its sporting nature. Quit spewing ignorance. Rx7 > all The Op wasn't asking about 8v's out of old golfs or b18's from honduhs, he wanted to know everyone's opinion on the value of an LCE turbo setup. |
#47 (permalink) | ||
Quote:
![]() Quote:
#48 (permalink) |
#49 (permalink) |
Your original post said something like the dyno run showed something like 197 hp and 237 ft/lb torque at the wheels... considering stock 22re is around 110 hp and 140 ft/lb at the flywheel... I think it's fairly safe to say it's nearly a 100% increase in power after factoring in driveline losses.
I wouldn't expect it to last as long as a stock 22re though, but if taken care of it could easily hit 100,000 miles. ...for the displacement junkies... boosting an engine to 1 bar or more is a displacement increase: it's being force fed over twice the air than it would otherwise consume and a corresponding amount of fuel. |
#50 (permalink) |
Im surprised none of you have mentioned the 22re's lack of efficiency. Its not a really efficient motor at all, like the other people said it was built for torque.
I dont like knocking on other people, but seriously you are going to argue that a 4cyl can make as much power as a V8 with the same mods. Get real people. Its common knowledge that it costs more money to get 400hp out of a 4cyl than a V8. And dont get me started on hondas, subies, mitsus, etc. Yeah they can make good power, but you are also talking about DOHC motors with hemispherical combustion chambers, the 22re is a SOHC with a horrible head design, its really restictive and not very efficient as I said earlier. The most I have ever heard powerwise out of a 22re motor was 250hp, after that you are looking at custom everything, when someone gets 300hp out of a 22re it will be a miracle, and they will have a huge wallet. Now back to LCE, they are the best out there, and the amount of time they worked on it probably amounts to that much money. They are a very good quality company! They may not make that much power but I bet if you spend 6k on doing everything yourself, you will be disappointed cause these engines just dont make that much power.
__________________
-Colton- 1989 Toyota Pickup DLX, 22RE, 5-spd, 5-in SAS, Detroit back, ARB front, longs, 37/13R15 Boggers, Marlin front and rear bumpers, Marlin sliders, Ramsey Patriot 9500 winch with synthetic line, Hi-angle D/S F&R, diff breathers, rebuilt tranny, 22RE bored .20 over completely rebuilt (it feels great to not have to buy 2 cases of oil a month!!), whole truck built in memory of my dad (RIP 6-26-08) Daily driver & tow vehicle: 02 Dodge 2500 Diesel, 5-speed, 4wd, quad cab, longbed, 128k miles |
| Tags |
| 22re, 4runner, build, camden, engineering, engines, fastest, header, hp, kit, lc, lcengineering, specs, supercharger, torque, turbo |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Towing Disappointment | TUNISIA | 95.5-2004 Tacomas & 96-2002 4Runners | 27 | 05-28-2008 04:02 PM |
| turbo motor | weaselman | 86-95 Trucks & 4Runners | 13 | 05-21-2008 08:39 PM |
| turbo motor | dcg9381 | 86-95 Trucks & 4Runners | 11 | 10-17-2006 12:53 PM |
| disappointment | luvmytruck | Off Topic Talk | 6 | 01-14-2005 04:24 PM |
| LC Engineering Turbo Kit? | YotaTruck1986 | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 01-09-2005 06:11 PM |
