Lack of power,sputtering 88 4x4 pickup
Old 11-20-2009, 03:13 PM
Weatherby's Avatar
Hi all,I have a 1988 toyota 4x4,short box,regular cab.When I go to accelerate,the truck starts sputtering,and doesnt have any go in it.Sometimes I have to rev it up to 4,000 rpms before I shift gears.I cant get the truck over a 100 km on the freeway either.I had the fuel filter changed a couple months back,new air cleaner.What could be the problem?
Old 11-20-2009, 03:16 PM
buckz6319's Avatar
what motor.....?
Old 11-20-2009, 05:00 PM
Weatherby's Avatar
Originally Posted by buckz6319
what motor.....?
it has the 4 cylinder fuel injected
Old 11-20-2009, 07:04 PM
93YotaMonster's Avatar
check your timing, valves maybe change your spark plugs, wires, cap and rotor button.
is it throwing any codes?
Old 11-21-2009, 10:00 AM
Weatherby's Avatar
I'm not sure what you mean by throwing codes.But it does have the charge battery light and e brake light lit up on the dash.
Old 11-21-2009, 10:54 AM
what i meant was, is the check engine light on and if it is, what codes have poped up.
Old 11-21-2009, 12:22 PM
DupermanDave's Avatar
Doesn't that mean the alternator is bad? Or at least there's a problem with the charging system?
Old 11-21-2009, 11:39 PM
Armalite's Avatar
check the cat sometimes they get clogged and rob power but i don't know if that causes sputtering or not. hope that helps
Old 11-22-2009, 11:45 PM
86 TOY's Avatar
Similar issues in my '86 w/22r, 4WD, 5 spd. Seems go away once the truck warms up. Truck has been tuned up, new plugs, hoses & belts, oil & filter changed. Yes, I'm a newbie... any ideas?
rondogracing
25
12-11-2015 07:26 AM
1badyota350
06-28-2015 06:50 AM
toy89yota
06-24-2015 01:18 PM
nyk08trx
06-18-2015 09:01 PM
Quick Reply: Lack of power,sputtering 88 4x4 pickup
