Knock sensor wire queston
Where does the wire that plugs into the knock sensor pigtail come from ?
Can't seem to find the wire that plugs into the knock sensor ?
90 4runner 4x4 5 speed 3vze
As you can see there are only two plugs(each side) coming out of the harness that runs along the top of the engine.
I've looked around pretty well for another plug in the motor bay.
We talking about the 3vze?
On my rigs, it comes up through a notch in the intake manifold almost directly under the throttle body.
It's a lot easier to access if you remove the tb.
Looks like I need to pull the manifold and re-route that piggy.
I took the thing apart in April, that's what happens when it takes too long to get back together, I was looking at them notches when I re-assembled it.
Thanks gents.
Thanks gents.
Yep, I routed the wire the wrong way.
Pulled the intake manifold off, re-routed the pig tail.
Problem solved.
Tip: take more pix during dis-assembly, better yet film dis-assembly with a Go-Pro.
Problem solved.
montanatruck
02-26-2017 07:07 AM
Steven.m.paulk
07-24-2015 01:44 PM
88yodabasket
07-13-2015 01:32 PM
