Knock sensor issue
Old 04-08-2012, 06:58 AM
GRINDER32's Avatar
Knock sensor issue
I just rebuilt the motor in my 88 22re from oil pan to valve cover, everything new, including a knock sensor. But now a month or so later my knock sensor engine code is up on my dash. I also have a really high idle when I pull up to a stop sign for example unless I bump the throttle pretty good then it idles down. I'm just very confused on why my idle would be doing this and secondly my knock sensor. I don't want to spend another 200 on a new knock sensor to find that the sensor itself wasn't bad. Are there other things in relation to the sensor that throw a code 52?
Old 04-08-2012, 07:09 AM
rworegon's Avatar
Did you replace the knock sensor wire at the same time?
Old 04-08-2012, 07:34 AM
GRINDER32's Avatar
No I did not, only the sensor. Are the sensor wires readily available?
Old 04-08-2012, 07:53 AM
spinyard's Avatar
it's the wire they go bad all the time
Old 04-08-2012, 08:01 AM
rworegon's Avatar
Dealer only item, special order. Probably less than $15-20. The sensors hardly ever go bad. Wires get killed by heat.
Old 04-08-2012, 08:27 AM
GRINDER32's Avatar
Ok awesome! 15 is much better than 200! I'll order that so I can do it while my injectors are being rebuilt
Old 04-08-2012, 08:36 AM
rworegon's Avatar
Check with your dealer for the correct part number on the wire. They did change right about '88.
Old 04-08-2012, 08:48 AM
volfsar's Avatar
go to the dealer with your wire, so they get the right one for sure, they always order the wrong one
Old 04-08-2012, 09:43 AM
drew303's Avatar
$200 for a knock sensor!? Jesus lol I just gave one away for free last week
Old 04-08-2012, 02:40 PM
GRINDER32's Avatar
Knock sensors are very pricey, at least to me lol. Gotta love a high school budget! But I will run up to my dealer and get them to order me the correct wire. It is just odd to me because the light comes on randomly and only after driving about 15-20 miles.
Old 04-08-2012, 02:59 PM
swerks's Avatar
let us know if the wire does the trick
Old 04-09-2012, 08:17 AM
drew303's Avatar
Next time just go to the junkyard and get one
Old 04-09-2012, 08:31 AM
scope103's Avatar
The knock-sensor pigtail fails all the time from age. You'd put an "old" wire in to save $10? I don't think I'd do that even if it was easy to get to, and the knock sensor wire is anything-but.
montanatruck
02-26-2017 07:07 AM
nonstop
07-24-2015 06:29 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
keithporter83
07-18-2015 12:37 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: Knock sensor issue
