| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Knock Sensor- Help needed fast!
__________________
1988 4Runner 3.Slow -33x12.5 Mickey Thompson Baja MTZ Radials -4Crawler 1.5" BJ Spacers -OME 2" Leaf Springs -Flowmaster 44 -Engine replaced at 200k -Green Rattle can paint The early bird gets the worm but the second mouse gets the cheese. Hmmm... See more in the Check out my Truck section God works through Christians; I am a Christian. -George W. Bush |
#2 (permalink) |
Hope this helps
![]() ![]() It is left of the oil filter if your engine is a 22RE
__________________
1991 Toyota PU, 4wd, 5spd, 22RE..SOLD 1980 Yota PU LB 4x4 5spd (swap) 20R, weber carb bone stock..Sold 1984 4Runner, 4" lift, 33's and hopefully more to come |
#3 (permalink) |
oops my bad im sorry, i should have listed that my engine is the 3vz the 3.0
__________________
#4 (permalink) |
It plugs into the harness that comes from the passenger side to the front (top) of the engine and then to the distributor, alt, tps, knock sensor and injectotrs, etc...
__________________
1995 Toyota, 4x4, XT, Cab, 5 spd, 2" Trailmaster Lift, Downey Headers, BFG KO's Last edited by DirtCheap; 08-14-2006 at 08:23 PM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22re Knock sensor vs 3.0 knock sensor | tlake | 86-95 Trucks & 4Runners | 4 | 01-30-2008 09:53 AM |
| Knock sensor? | cmckeon | 86-95 Trucks & 4Runners | 1 | 01-21-2007 09:20 PM |
| Toyota Knock Sensor needed???? | pitm96 | 86-95 Trucks & 4Runners | 4 | 12-24-2005 10:40 AM |
| Where is the Knock Sensor???? | pld15 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 04-15-2005 06:26 PM |
| Knock sensor again | Bassinfool | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-15-2005 11:28 AM |
