knock sensor
Old 10-17-2009, 09:46 PM
jrlydy's Avatar
knock sensor
does the knock sensor have to be replaced when you blow a head gasket?
Old 10-17-2009, 09:59 PM
Jason4X4's Avatar
not unless it's bad.
Old 10-17-2009, 10:00 PM
jrlydy's Avatar
how do i know if its bad
Old 10-17-2009, 11:00 PM
TNRabbit's Avatar
Usually, it's the pigtail wire from the wiring harness to the KS that goes bad (well, ALWAYS). The KS itself seldom is bad.
Old 10-18-2009, 08:08 AM
sb5walker's Avatar
What engine??
If 3vze, replace the pigtail.
Old 10-18-2009, 08:46 AM
muddpigg's Avatar
I used a hammer, vise, and multimeter to check for mine. Not super accurate as it won't tell you if its the same pitch as an engine knock. But I felt better after hitting something with the hammer all scientific like
Old 10-18-2009, 08:53 AM
Team420's Avatar
If your going to be in there any way....its best to replace it. Trust me.... been there done that.
Old 10-25-2009, 07:40 PM
jrlydy's Avatar
where in hell do you find the pigtail at? napa doesnt have it
Old 10-25-2009, 07:48 PM
dustins's Avatar
Where is the pigtail, might be a stupid question.
Old 10-25-2009, 07:51 PM
camo31_10.50's Avatar
wtf is a knock sensor???????? llmao
Old 10-26-2009, 04:33 AM
Team420's Avatar
the pigtail exits thru a notch in the drivers side head, just below the throttle body. To change it, u have to pull the throttle body, then the upper plenum, then the intake manifold, the ks will be right under the mani in the valley. If u are going to change the pigtail... I would change the sensor itself. Not much sense in replacing just the pigtail to find out the sensor needed replaced too after u get it all back together..
Old 10-26-2009, 11:12 AM
bugs1961's Avatar
The part number for the pigtail is 82219-89103 and it's called "wire, sensor". Retails for $13 at the dealer. Definitely replace the wire as it gets really hot, causing it to get brittle over time and eventually shorts out on the head. Knock sensors are around $200 and very seldom fail. Your money of course, but I have replaced several pigtails and never a sensor. Fixed the problem each time.
jb451
7
10-07-2022 06:58 AM
1uzRunner
63
11-10-2018 03:58 PM
Kreedy1
09-08-2015 06:33 PM
moparbay
09-03-2015 12:48 PM
northwalker
09-03-2015 12:21 PM
Quick Reply: knock sensor
