knock sensor...
Old 04-28-2009, 08:46 AM
dcmbsc's Avatar
knock sensor...
I think I have a bad knock sensor and/or bad wire harness. How hard is it to replace and where in the hell is it located, can not find it!
94 v-6
thanks!
ps pictures would be great!
Old 04-28-2009, 09:26 AM
Staff
DeathCougar's Avatar
Go up to the right hand of the screen, click "search" and type in Knock Sensor
K? Thxbai
https://www.yotatech.com/forums/f116...or-help-74203/
https://www.yotatech.com/forums/f2/n...-sensor-49373/
https://www.yotatech.com/forums/f16/...-theirs-58531/
Old 04-28-2009, 09:54 AM
dcmbsc's Avatar
IS that it?
Old 04-28-2009, 10:16 AM
GSGALLANT's Avatar
No. I answered this question in your other post.
Old 04-28-2009, 10:26 AM
Staff
Uh no, that is your oil pressure sender.
Again, CLICK ON THE LINKS and READ.
It is underneath the intake, you will have to remove your upper AND LOWER intake manifolds to access it.
Old 04-28-2009, 10:28 AM
dcmbsc's Avatar
That sounds like a job, Ive never done anything like that before... not good.
Old 04-28-2009, 10:42 AM
83yota6996's Avatar
Its under the intake manifold between the heads FUN!
Old 04-28-2009, 10:54 AM
dcmbsc's Avatar
haha i called toyota to see how much , 180 for the sensor , 600 for labor, looks like i getting my hands dirty.
where is a good place to get the wire? is toyota the only place?
Old 04-28-2009, 11:19 AM
GSGALLANT's Avatar
Get it at Toyota. It's cheap and durable.
Lummpus's Avatar
KNOCK SENSOR LOCATIONS
Model Location
Pickup 2.4L 4WD In Cylinder Block, Below Air Cleaner
Pickup 3.0L In Cylinder Block, Below Air Cleaner
REMOVAL
Disconnect negative battery cable. On all models, disconnect knock sensor connector. Using Knock Sensor Socket (SST 09816-30010), remove knock sensor. Using ohmmeter, ensure there is no continuity between terminal and ground. If there is continuity, replace knock sensor. To install, reverse removal procedure. Tighten knock sensor to 33 ft. lbs. (44 N.m).
moparbay
03-10-2023 03:50 PM
some drunk guy
08-03-2021 06:09 PM
Marley2984
12-06-2015 05:19 AM
moparbay
10-06-2015 09:24 AM
ac7822
09-11-2015 08:49 AM
Quick Reply: knock sensor...
