| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Killer Vacuum Leaks
__________________
88 pickup, 22re, 2 inch body lift, 33inch BFG all-terrains, K&N intake system, 127,000 OD miles |
#2 (permalink) |
__________________
86 Runner with rebuilt 22re and 5 speed swap |
#3 (permalink) |
Some pix. on my web page:
- http://www.4crawler.com/4x4/CheapTri...ine_Pix/1.html Best thing is to get a factory service manual (FSM) and check out all the chapters and come up with how things are supposed to be connected and what each line is supposed to do. That is how I did my engine.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#4 (permalink) |
you know what sucks... not being able to read any of the diagrams... maybe thats why im not a contractor... just read em carefully and try not to mix up any vacuum lines...
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22re, 1200 miles on the rebuild engine builder .268 cam pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread |
#5 (permalink) |
thank you guys the one i need is only in one of the pics off pirate but i cant tell where it goes i looked all under the efi manifold but no clue where can i check out one of these factory service manuals
__________________
#6 (permalink) |
Go to www.ih8mud.com and look in the FAQ there are links to FSMs for a range of years. They are also on 4x4wire and may even be here as well.
http://forums.bauchan.org/portal/downloads.php http://www.toyotanation.com/forum/sh...37&postcount=2 http://www.ncttora.com/fsm/
__________________
86 Runner with rebuilt 22re and 5 speed swap Last edited by Luvmeye22re; 10-29-2007 at 11:08 PM. |
#7 (permalink) |
check the power steering pump some have a idle up valve on them and the hose is slightly bigger then the other lines.
__________________
my rigs 89 4runner 1989 4runner v6 5 speed everything factory +4susplift running bfg 31s and a aux gas tank and more aux lights than needed 86 pickup 1986 stock pickup 22r 31.10 BFG ATs flatbed a sad day for the 4runner "One moment of patience may ward off great disaster. One moment of impatience may ruin a whole life." |
#8 (permalink) |
#9 (permalink) |
ya so i found out that it actually wasnt a vacuum leak and it turned out to be the egr valve i got to figure out where to put the end of the vacuum line goes could it affect my idle that much it sounds like its retarded but all the timing is on i checked
__________________
#10 (permalink) |
The EGR and modulator lines are all labeled and connections are fully documented in the Factory Service Manual.
__________________
#11 (permalink) |
i fixed all my vacuum lines but now i am stuck with an exhaust leak but dont know where ist coming from. i checked all the egr bolts and the manifold bolts they are all tight. the plate on the back is tight as well i am stumped
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Coolant leaks and oil leaks on a 91 4runner | L33mur | 86-95 Trucks & 4Runners | 5 | 05-21-2007 01:37 PM |
| Killer Cardio | tacoma728 | Off Topic Talk | 3 | 01-30-2007 04:59 PM |
| Checking for Vacuum leaks/carb clearner | rdharper | 86-95 Trucks & 4Runners | 4 | 11-11-2006 09:03 PM |
| too lean CEL, what's a good way to check for exhaust leaks and vacuum? | firedog | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 12-11-2004 07:45 PM |
| 97 4Runner rear axle leaks - HELP an Aussie !! R cannot stop leaks !!! | beddo | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 08-06-2004 05:48 PM |
