Key wont Turn my Ignition
Old 07-23-2010, 07:15 PM
4runner530's Avatar
came back from camping, the next day I tried to start my truck and it wound not turn over at all ... I turned the wheel, banged on the steering wheel... pretty much tried everything
could it be an old worn key or could it be my ignition is ed
any ideas?????????
Old 07-23-2010, 07:18 PM
89silverpu's Avatar
Try lightly removing it and wiggling it around, mine does it sometimes too and just wiggling it easily sometimes works better than more force
Old 07-23-2010, 07:27 PM
4runner530's Avatar
still dont work, just got done sweating bullets trying to get it done,,
Old 07-23-2010, 08:37 PM
85TurboRunner's Avatar
My runner does that sometimes. I just have to wiggle the key and the steering wheel till it works. Sometimes it takes quite a while.
Old 07-23-2010, 08:53 PM
dewiseman's Avatar
Mine does it too. Getting a new key made helps some.
Old 07-23-2010, 09:00 PM
95blackToy's Avatar
I had that problem it would only sometimes do it then it got to where it wouldnt work at all. I tried new keys and graphite lube and wouldnt work. i had to dake off the dash and replace the whole key cylinder and bracket that holds it to the steering column. Can you get the key to accessory ?
Old 07-23-2010, 09:38 PM
85gijunk4x4's Avatar
lol, i bet if you stuck the key to your house or something in there it'll work like brand new!!!
Old 07-23-2010, 09:51 PM
ET
ET's Avatar
yep. i had a key like that. turn it like normal and if it stops just saw it back and forth slowly. it should catch and you can turn it on. but yes, it's a worn key. if you don't have a good one to copy take out your passenger door handle and have a key made from that lock.
Old 07-23-2010, 10:13 PM
95blackToy's Avatar
mine was messed up. It had no chance of turning any key. It was a PITA to get the cylinder off of the steering column. Had some kinda bolts without heads from the factory, like it was twisted off on purpose.If he can get it to accessory he can just push the little release button on the bottom of it.
Old 07-23-2010, 10:37 PM
Armalite's Avatar
You don't need a key just grab a screw driver and get angry lol. my truck was stolen from the PO that way : (. They broke the plastic around the key cylinder jerks.....
Old 07-24-2010, 03:02 PM
4runner4life93's Avatar
My does that all the time move the shifter untill you can turn it
Old 07-24-2010, 08:18 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
There's an old thread around here that talks about this very issue. I'll see if I can find it tomorrow when I have more time. I had it happen to me once at a gas station maybe four miles from home. I pull everything apart until I figured out to fix it. I just don't remember what I did right now.
Old 07-25-2010, 04:51 PM
Murakami's Avatar
you have to move the key around while trying to turn it. i know you tried this already but you need to move the key up and down vertically, parallel to the key itself, and turn.
Old 08-20-2010, 11:27 PM
jodysinhawaii's Avatar
Thumbs up Easy fix with right tools
96 4- runner 4 cyl.
My key wouldnt turn to the start position, it just stopped no matter how much I wiggled it and made love to it I just ended up with a gigantic blister on my finger. I called a locksmith and after a few quick questions he was taking my dash apart. he made his way to the ignition and used a allen wrench to loosen the set screw that holds a cylinder wich in turn holds the tumblers. After close inspection he determined the lock ring was cracked and there were a few other bits of soft metal in there causing it to jam, I would of needed another anyway. After removing it he drilled out 2 other set screws that hold the tumblers. I told him I didnt mind using my house key to start my car so he removed the tumblers completely. Re-assembled the cylinder minus 1 piece and tumblers and I was good to go. I had to take it apart to put the beauty ring back in and it was very easy to disassemble my dash and have at the ignition. I would rate this quick D.I.Y. at easy to medium difficulty depending if you are using a butter knife or a few tools you could find in your nieghbors garage. I could easily buy a new cylinder and replace myself knowing how easy it was. But I like using a butter knife to start my car.........
theking11863
03-19-2016 09:36 PM
TDonkey
07-26-2015 10:14 AM
luckypig44
07-19-2015 11:25 AM
Hamonacracker
07-17-2015 08:33 AM
Odin
07-15-2015 09:28 PM
Quick Reply: Key wont Turn my Ignition
