Key wont turn ignition. Need help
Old 07-20-2008, 07:44 PM
fooddude's Avatar
hey all i got in my 95 4runner today and tried to turn the key and it wouldnt budge. I wiggled my steering wheel, rocked the car back and forth, and even got out my spare key thinking mine was too worn down. Anyone have any idea what the problem is. I drove the 4runner just a few hours before this happened and have never noticed any minor issues before this. Any help is greatly appreciated.
Old 07-20-2008, 07:50 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
If the key won't turn in the ignition, try blowing into it, or tapping in it. Maybe you got dirt in the tumblers, keeping them from turning. If that don't work, take it out, and get a new 1 from the stealership.......
Old 07-20-2008, 07:52 PM
CJM
CJM's Avatar
Ignition is bad, gotta change it.
Old 07-20-2008, 07:56 PM
Jay351's Avatar
Key in, turn, key out. Repeat a few times.
If it doesnt work, you need a new ignition cylinder.
Old 07-20-2008, 07:57 PM
abecedarian's Avatar
dealer should have a record of the key cut. so take proof you own the truck to the dealer and they can cut new keys, and will let you test them out.
I had to do similar and got two keys for 10 bucks plus tax and they both work the doors and ignition like new.
Old 07-20-2008, 09:59 PM
fooddude's Avatar
well luckily for me i work at the "stealership" so ill get this stuff at work. Is the ignition easy to replace or am i going to have to have one of the mechanics do it.
Old 07-20-2008, 10:32 PM
Hey fooddude, which spintech setup/muffler are you running? I had 1 on my old 91 truck, but forgot the numbers, and want to do the same on this rig
Old 07-20-2008, 10:36 PM
SpecialScottie's Avatar
This same thing happened to me on my 95 runner.
The ignition wouldnt turn because the key was so worn down. I used my spare for a while and then got a copy made of the spare and it works fine now
Old 07-21-2008, 03:06 PM
fooddude's Avatar
well its definately my ignition cylinder. Anyone have any writeups or anything on how to change one of these. I dont really feel like having one of my mechanics charge me a lot for something that could be an easy fix.
Old 07-21-2008, 03:12 PM
Fossilized
Staff
dropzone's Avatar
see the link to FSM manuals in my signature. I am surprised none of the mechanics or service writers at your dealership you work at won't hook you up with at least photocopies of the manual...
Old 07-21-2008, 03:13 PM
offer the mech a few bucks or case of beer or whatever for him/her to do it in their spare time.
Old 07-21-2008, 07:57 PM
fooddude's Avatar
i might offer a mechanic a few bucks to do it, but i would rather do it myself if possible and save the towing fees. THanks for the manuals ill definately check them over.
Old 07-22-2008, 04:18 AM
WFO
WFO's Avatar
Its pretty straight forward. You just have to pull the lower dash off, there are cones on the head of the bolts holding it to the steering column, I guess so it cant be easily stolen. Well I drilled mine out, but after seeing that they werent even tight im sure you could just use and old socket and drive it on the cones and just take them off. Then one connector and put it all back together.
Same thing happened to mine a month ago.
Old 07-22-2008, 12:37 PM
just a 22re's Avatar
ok mine does the same one day it likes me and lets me turn her on and the other she dont even let try to turn her on!
heres what do do (my ing might be shot as any key with a lil help will turn it)
put key in jiggle
tAKE key out spray with pb
but key in jiggle
key out
key in and turn with a lil pressure and jiggle it should turn just fine
jiggle up and down and all around too
hope this helps you out man if not just take the plastics off the calom and get key to on oh dang yeah um ok i dont know how to get your ing out with out brakeing something man sorry try the first step i said first buddy hope it helps
Old 07-23-2008, 09:15 PM
X-Tool Pimp's Avatar
MOD EDIT: (Lysmachia) BANNED!
JHalcyonM
08-04-2015 01:19 PM
mluz013
08-02-2015 05:00 AM
TDonkey
07-26-2015 10:14 AM
Hamonacracker
07-17-2015 08:33 AM
Odin
07-15-2015 09:28 PM
Quick Reply: Key wont turn ignition. Need help
