Just swapped in another 22RE and need help
Old 05-23-2011, 04:53 PM
bmaurice's Avatar
I have A 94 22re just got the engine in . It starts sounds good but has no throttle response and goes from all the way high oil presure and drops to zero. My mechanic helping me seems to think he mixed up the knock and pressure switch. He cant look at it untill this weekend. The yellow wire goes to oil prsr switch and red goes to knock snsr. Please help despritly need my truck back.
Old 05-23-2011, 05:20 PM
bmaurice's Avatar
He also replaced the chain guides water and oil pump I read somewhere here u have to prime the oil pump.?I don't believe he did that
Please don't tell me my engines fried. It's sounds ok. Another wierd thing I have no check engine light on... It feels like it's starving for gas...
Old 05-24-2011, 06:35 AM
BigSwole's Avatar
Start off simple.
If it sounds like its starving for gas. Check the gas. Is the fuel filter clogged. There are thousands of possibilities it could be. Start eliminating them.
What all did the mechanic do?
Old 05-26-2011, 06:13 PM
bmaurice's Avatar
Run bldr timing chain kit, wrt and oil pump fuel filter, egr,valve,gromit, fan clutch,radiator,thermostat,oil prsr switch . Pry forgetting stuff bought the engine replaced everything logical and here I am.
mskalmus
05-28-2017 07:51 AM
coleypull15
11-03-2015 07:41 AM
steve miller
10-10-2015 01:40 AM
deepmarsh
08-06-2015 03:44 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Just swapped in another 22RE and need help
