Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Just replaced knock sensor and now truck wont start PLZ Help
I just replaced the knock sensor wire and now my truck wont start.. i adjusted the timing to see if anything, but nothing, so i checked for spark on the plugs and that went good... im out of ideas as of right now,,,, im in need of some quick help..
__________________
95 4runner 3.0L V6 31X10.50R15 Pathfinder A/T K&N Intake Flowmaster 40 series muffler magnaflow high flo cat |
| Sponsored Links |
#2 (permalink) |
All the hoses on correctly (esp. fuel lines)?
Check your fuses (esp. EFI)? |
#3 (permalink) | |
iirc, the knock sensor wire is a shielded wire, meaning there is a center conductor surrounded by an insulating core and a grounded, woven shield. make sure the center and shield are not shorting out.
__________________
Quote:
#4 (permalink) | |
Quote:
i cheked the fuel line and i jumped the wires for the fuel pump and everything went good... I also did check the fuses and they were good to
__________________
#5 (permalink) |
how would i check for that, or is there even a way....
__________________
#6 (permalink) |
i took off the timing cover and noticed that the marks on the cam sprocket werent aligned right.. would that be a good cause to the problem, and also when i was trying to start it, i unplug the knock sensor from the wiring harness and still no fire
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Newbie replaced Head Gasket, Truck wont start... | StillAHondaFreak | 86-95 Trucks & 4Runners | 134 | 07-17-2008 04:29 PM |
| Replaced knock sensor...still code 52??? | Saint_Berzerker | 86-95 Trucks & 4Runners | 8 | 06-01-2006 06:35 AM |
| help truck wont start | 88yotaboy | Maintenance & Repair Archives | 17 | 04-18-2005 03:33 PM |
| No start after knock sensor replacement | patterson | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 08-02-2004 04:58 AM |
