just had alignment and still shakes in the steering
Old 01-23-2010, 03:18 PM
Tattoo Mike's Avatar
i have a 95 pickup that i did a complete over haul of the front end.new tierod ends, pitman arm, idler arm, power sterring pump and ball joints. I also added ball joint spacers.it rides great untill i hit 55 then i get a slight shake in the sterring wheel. can this be from the cv shafts.or is it something i missed
Old 01-23-2010, 03:43 PM
waskillywabbit's Avatar
Improperly balanced tires.
Old 01-23-2010, 03:48 PM
MaK92-4RnR's Avatar
Old 01-23-2010, 04:01 PM
Fink's Avatar
Fink
Old 01-23-2010, 04:25 PM
betelnut's Avatar
Yeah, or tires with a lump. I've seen slipped belts, weak spots and other tire defects cause this. Try rotating your tires and see if it changes anything.
Old 01-23-2010, 06:03 PM
desertcamper67's Avatar
All of the above or a bent rim. Sounds to me like a tire most likely.
An alignment doesn't fix a shake. Ever. Replacing something worn, bent or out of round and balancing tires does.
Old 01-23-2010, 06:12 PM
YoYoMa's Avatar
Does the brake pedal shake when you brake...If so, warped rotors. If not, tires.
Old 01-23-2010, 06:39 PM
myyota's Avatar
It could also be loose or worn wheel bearings.
Old 01-23-2010, 07:19 PM
just put brand new tires and rims on truck going to swap tires around in the morning and no i dont feel anything in the break pedal but just heared new noise when driving at 5 mph and turning to the left i hear a clicking noise
Old 01-23-2010, 08:00 PM
livetoride88's Avatar
if its clicking when turning ur cv is prolly about to go out but that shouldnt cause a shake at speed but it may
Old 01-24-2010, 05:36 PM
christopher_2's Avatar
Look at the amount of weight added to each wheel to balance the tires. Does one of the front have a lot more as in two or three times then the rest if so that tire may have a problem.
calderp
11-16-2015 02:49 AM
gyroscope7
09-21-2015 04:55 AM
Kylenicoll33
09-17-2015 08:40 AM
89hilux1
09-14-2015 06:13 PM
128keaton
09-03-2015 05:09 PM
Quick Reply: just had alignment and still shakes in the steering
