just done 7mge maf swap
Hi
swap has been done using orginal air box had to cut top off ehere maf sits. engine feels so much better. no air restriction now all i can hear at tick over is air being sucked in. when cruising at 50mph engine is quieter and engine temp is now 1/4 insyead off a 1/3 on temp gauge. See how mpg figures compare to before and after. next is exhuast upgrade to 2 1/4" and fit my flamethrower injectors. should be and interesting combination :-)
Ended up using a maf adaptor plate and cone filter. Understand you can use a 1987(?) - 1993 toyota supra non turbo air filter box with its pipe work instead.
Tacoma1313
08-17-2015 05:44 PM
