Just checked my fuel pressure
22re 23lbs. book says I should have 38-44. Could this be why my truck has been throwiing codes? 24,25,31,41? Alot of you have help me check different things this past week, like the AFM TPS Timing. Could it been that it wasn't getting enough fuel? I took the filter off and blew throuh it and it wasn't plugged. just to be sure I got a new one and blew through it and it was the same. So now I guess it's down to the fuel pump right?
I tested after the regulator ant the cold start injector. With the truck running it reads 25psi. not running 23psi. I was going to check the psi befor or after the fuel filter but I don't know what the pump should be putting out.
Another thing is that it is not holding pressure when the truck is shut off. Testing at the rail the FSM says it should hold at least 21psi for 5 min. Goes right to 0.
Oh! well it could be the regulator then.
I would study this diagram carefully:
http://personal.utulsa.edu/~nathan-b...23descript.pdf
It kind of looks like to me the cold start injector is up line of the regulator, but I'm not sure.
You could MOMENTARILY pinch the return line and see if the pump is capable of higher presure (return line is at rear of manifold, towards the charcoal canister)
If it does get higher, may be bad pressure regulator.
Also clamp off return, then shut off truck. If it then holds pressure the regulator is bad. If it does not hold pressure, could be the pump (checkvalve inside)
That's odd.. Mine reads 44psi while running.
I've got a spare reg if you decide you need one... But I'd replace the inline filter and maybe the sock filter first.
YODA is very right to check your pressure regulator. The way it works is to restrict the fuel flow enough to maintain the proper pressure. If it's bad in a manner to cause low pressure it is likley to cause the bleed down of pressure as well.
Crimp off the return line while measuring the pressure at the cold start injector. The pump should be able to get 80 - 100 psi. if it does not increase look at the pump. If it does increase you'll be needing a pressure regulator.
Proper testing is the way..........
Grasshopper
P.S. leaky injectors can also cause bleed down
Grasshopper
The 85 factory manual says 33-38 PSI with vac line disconnected, and 27-31 PSI with it connected. ( Other years may be different)
Hey hey figured it out. I put a pressure tester on the line before the filter. Still 23psi. So I bought a new fuel pump. Droped the tank and pulled the pump up. Wala the hose that connects the pump to the hard line had pulled off on one end. I thought hell why I'm in here should I replace the pump or take my chances? For $230 I took my chances. Now I have 38psi without the truck running and 44 when running.
I'm thinking that this has been all of my problems. Like the AFM signals and bad TPS signals. I think the computer was telling it to adjust for the fuel that it was'nt getting.
Thanks everyone for the help. I'll drive it tomarrow and see how she does.
I think it's performance engineering that offers walbro pumps for the toyota truck/4runner for around $100..... Second thing is that my truck doesn't hold pressure for 5 minutes either. It drops fairly quickly after the pump is shut off.
