Just can't decide... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-03-2009, 10:08 AM   #1 (permalink)
MKW
if 35/12s will fit on my truck or not. I have a 89 with a 4" suspension lift. I am running Soft 8s (15x8) with 4" backspacing. I bought 33s with the lift, but looking at it now, it looks like 35s will fit pretty easily. My truck basically stays on the street and I'm not willing to hack it up. I will pound the pinch weld if needed, but that's about it.
Sooo...will 35s fit with 4" of lift without rubbing??
Mike
MKW is offline
Old 01-03-2009, 10:12 AM   #2 (permalink)
4banginRunner's Avatar
without ANY rubbing? no
my dads old 93 had a 4" bracket lift with 35s and on hard turns they would rub a bit
__________________
87 Toyota 4Runner
22RE--5spd swap (W56)--4.56s--BJ spacers--Pro Comp Stage II 4" bracket lift--63" Chevys w/2" blocks--40 series--late style steering box swap--BudBuilt Dual Case X-member--V6 calipers--32s--MC rear bumper--SAS parts collecting time...
79 Toyota Longbed 4x4
Frame-off Resto time.
04 GMC Sierra 1500
the DD
4banginRunner is offline
Old 01-03-2009, 10:18 AM   #3 (permalink)
tman12345's Avatar
Send a message via AIM to tman12345
maybe get BJ Spacers and something to match the back.
__________________
1995 Toyota 4Runner
Cruiser Coils, Bj Spacers, Aisin Manual Hubs, 4crawler Panhard Drop Bracket, Extended Rear Brake Line, Skyjacker Shocks, custom LSPV Bracket, 15x8 Cragar Soft 8's, 33x12.50x15 Mud King XT's, Marlin Crawler Rear Bumper
tman12345 is offline
Old 01-03-2009, 10:19 AM   #4 (permalink)
x2, small body lift would work too
__________________
87 Toyota 4Runner
04 GMC Sierra 1500
the DD
Old 01-03-2009, 10:35 AM   #5 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
Considering 31's will fit with slight rubbing w/out a lift, and 35's only add about 2" to the radius of the tire, it shouldn't rub with a 4" lift... but you're going 12" wide ... so you may rub at full lock ... but you've got 4" b/s so that may pull the wheel in a bit to help. You may rub on the frame with that...
You are very likely to rub the rear if you load the back up and compress the springs enough though.
See if you can get the tire shop to mount two up front and have a look. A lot of shops will mount them if they're confident you're gonna buy if they don't rub. Discount Tire (I was on a budget) mounted my 31's up front (265/75r16 actually, before I did the suspension lift) to check if they would rub at full lock (which they didn't)... and even jumped up and down on the bumper to help check for rubbing .
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 01-03-2009, 10:41 AM   #6 (permalink)
BigBluePile's Avatar
Send a message via MSN to BigBluePile
Yes, you'll be fine. I had to adjust the steering stops, but that was it. If you have 4" backspacing you'll be in better shap than I was with the 4.5" backspacing on my rims.
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
THE ULTIMATE TOYOTA RESOURCE
'86 4Runner SR5 22R-E
4" Procomp/Superlift/Rancho 9000x/BudBuilt skids. Downey Header/Magnaflow exhaust, Supra AFM. 315/75R-16 Baja Claws, 4.88's, TrueTrac rear.
Rear disk kit/trans e-brake. Addicted Offroad winch bumper/MM 9000
Current pics
'06 4Runner Sport
270/65R17 BFG All Terrain KO's
Admit it, you like reading my posts. It reminds you of the days before your runner was the monster that it is now.
BigBluePile is offline
Old 01-03-2009, 03:00 PM   #7 (permalink)
MKW
Oh, screw it...I'm getting 35s! Bottom line, I'm not happy with the way the 33s fit and it's only money, right? I'll make'm fit, one way or another!
Mike
MKW is offline
Old 01-03-2009, 04:03 PM   #8 (permalink)
BMC
BMC's Avatar
Another thing to think about is gears. Have you already regeared or do you still have stock gears? 22re or 3.0? Auto or manual? Bigger tires on stock gears makes a huge difference.
__________________
1987 4runner: 22re 5 speed 146,000 miles: LCE header: high flow cat: 40 series flowmaster: Rear downey 3" lift springs: Front 1.5 4crawler bj spacers: Skyjacker shocks: Aussie locker in the rear/open front: 31-10.50-15 Cooper stt's on pro comp rock crawlers 15x8: All-pro single bar version front bumper with custom stinger and side hoops: Smittybuilt xrc8 winch: KC slimlights: Rear marlin crawler bumper: 4xinnovations rock sliders with kickout: SS ifs truss: Budbuilt transfer case xmember:
BMC is offline
Old 01-03-2009, 04:06 PM   #9 (permalink)
yea if you have stock gearing, its gunna be one hellva dog
__________________
87 Toyota 4Runner
04 GMC Sierra 1500
the DD
Old 01-03-2009, 04:47 PM   #10 (permalink)
MKW
I just finished putting 4.88s in today, so I'm good there. I've got a strong 22re with a 5speed.
Mike
MKW is offline
Old 01-03-2009, 05:31 PM   #11 (permalink)
where's that 'balls to the walls' emoticon?
__________________
Old 01-03-2009, 07:06 PM   #12 (permalink)
MKW
Quote:
HaHa...yeah, I ain't scared!
Mike
MKW is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Can't decide.... TransAmBandit Off Topic Talk 5 10-01-2007 02:22 AM
Help me decide dp Off Topic Talk 16 12-31-2006 03:04 PM
HELP ME decide what to do... JonathanG32 Off Topic Talk 1 05-23-2006 09:48 PM
cant decide what to go with bulletproof Offroad Tech 6 07-28-2004 07:20 PM
Can't decide what to do?? defigh 95.5-2004 Tacomas & 96-2002 4Runners 3 06-03-2004 08:27 PM
2009 InternetBrands, Inc.
