Just bought a 91 p/u and have a power steering question
Old 10-12-2011, 04:47 PM
Druyota94's Avatar
I was wondering if I could buy a smaller belt and do away with the ps or is that not possible?? I've never changed a ps pump, just need a quick fix for now...
Old 10-12-2011, 04:52 PM
rokblok's Avatar
I believe that the P/S pump is also the belt tension adjustment. If thats the case you cant do away with it, otherwise you would have to "roll" a smaller belt onto the crank and w/p pulleys, with no way to ever adjust the tension...
Old 10-12-2011, 04:58 PM
Druyota94's Avatar
Thanks man, guess I'm changing it then.
Old 10-12-2011, 05:01 PM
rokblok's Avatar
If the P/S pump is permanently affixed and not used as a tensioner for that belt, then you could prob get away with a smaller belt and eliminating the pump on that belt. But if its a moveable, tensioner unit pump, then yeah, I would suggest changing it... Some pics would tell me better. Since this is the '84-'85 section, you may wanna check in the '91 section. Be sure to list your engine size...
Old 10-12-2011, 05:14 PM
Druyota94's Avatar
P/s question 91 p/u
I was wondering if I could do away with my p/s by buying a smaller belt and not use the p/s pulley. It's a 22re. I'm new to all this, just a noob question I guess..
Old 10-12-2011, 05:22 PM
MudHippy's Avatar
Dah...if you remove the belt, nothing else happens, you just lose your power steering(pump's no longer being driven). Unless that same belt is driving something else, like say an A/C compressor. In which case, bye-bye A/C too. As long as you have an alternator belt you're good to go(since that one drives the cooling fan too, and the water pump if 22R-E).
Old 10-12-2011, 05:42 PM
Druyota94's Avatar
I'll scope it out tomorrow, thanks fellas
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Quick Reply: Just bought a 91 p/u and have a power steering question
