Jounce or Air Bumps on Total Chaos LT
I was just curious if anyone here was running an air bump or Light Racing Jounce Bump on a Total Chaos LT A arm setup.
I was wondering where on the arm you set it up..
http://www.ttora.com/forum/showthrea...ghlight=jounce
The company guy asked the TTORA member to send feed back on the set-up for LT. Otherwise see the company site for bump mount location
but SCExploror's got a Taco with a UCA and a stock lower A arm.
I wnat to know if the twin A arm era TC LT setup can take a jounce shock and where it gets located?
Me thinks that I cut off the "rear" stock lower jounce point and fab up a bracket to hold a jounce shock there - but the TC LT arm looks like its just "tube" there so a pad ha to be fabbed ont he arm as well.
The JD Fab lower arms are boxed plate and look like they are easier to mod for the lower jounce shock
Thanks for the links..
A few links / threads later and theres this
http://www.lightracing.com/89ToyotCustomJounceShock.htm
Thats on a stock lower A arm...and with a 4" bracket lift (looks like an old TrailMaster Orange) but its a start on what needs to be done for the TC setup.
The ideal way (and way complicated way) is to french the mount into the frame rail.
The reality is to point them inside as per their rear method
For the front - it looks like they get mounted a bit higher than the ones in the slide show.
Also - the TC arms will need to be moded for the dome.
FS[GreatLakes]: 22RE performance and stock parts (pic heavy)
05-20-2016 10:27 AM
the1998sr5
27
11-17-2015 09:30 AM
ripp96
07-25-2015 02:32 PM
