ive got a pretty serious fuse prob
Old 08-24-2008, 05:07 PM
toyotanick's Avatar
ok, well i just realized that i have been running a 30 amp fuse as my 1990 toyota pickup EFI fuse when it only calls for a 15. so figuring that i was just out of 15's when i put it in i changed it back. well i left my dads shop and got about a block before it blew. so i have to run a 30 until i can figure it out.
does anyone have any ideas about what i could be? o and could this be a reason why my gas mileage is rediculously bad?!?!
Old 08-24-2008, 05:15 PM
abecedarian's Avatar
possibly.
check the wiring around the transmission for any wires that may be shorting.
you may be able to put a 15 in and shake the wires until you can make it blow.
Old 08-24-2008, 05:23 PM
toyotanick's Avatar
around the transmission? why would electronic fuel injection be around the transmission? o and this transmission is a manual if it makes a difference
Old 08-24-2008, 05:24 PM
the ecu powers lots of things...
anyhow, I've heard that O2 sensor wiring can short out quite easily due to where it runs.
Old 08-24-2008, 05:27 PM
toyotanick's Avatar
ooooo ok well ill slap a 15 in there and start shakin wires tomorrow, but if that isnt it what else could it be?
Old 08-24-2008, 05:39 PM
waskillywabbit's Avatar
Should be as easy to figure out as an SAS.
Cyberman's Avatar
I just blew my EFI fuse, after finding out that the wiring going down the side of the engine melted against the EGR tube.
Old 08-24-2008, 05:40 PM
just looked at a wiring diagram and on 89/90 trucks, the 15a EFI fuse powers the ECU and all the sensors.
toyotanick's Avatar
nah deinatelly not. this is electrical not mechanical
that's not nice... it's funny but not nice...
Old 08-24-2008, 05:41 PM
toyotanick's Avatar
alright ill check all of those things tomorrow, thanks guys
Old 08-24-2008, 06:09 PM
vtjeenyus's Avatar
also check the driver side frame rail where it passes beneath the engine
on mine the big pack of wires rubbed on the frame until it wore through
just an idea
Old 08-24-2008, 08:18 PM
just a 22re's Avatar
dont the efi fuse power the fuel pump to? not sure but that could be it unless im wrong but that never happens
Old 08-24-2008, 08:32 PM
toyotanick's Avatar
hahah way to be cocky! very nice. and is there any way to check the fuel pump or any tell tale signs that its going out?
Old 08-24-2008, 10:32 PM
annoyingrob's Avatar
Yes, get a multimeter, and test the current draw of the fuel pump. I wouldn't be able to tell you what's a normal reading though.
theking11863
03-19-2016 09:36 PM
cgilley
07-25-2015 10:55 PM
80Truck
07-24-2015 03:12 PM
Jonny246
07-24-2015 12:37 PM
rushw
07-18-2015 01:46 PM
Quick Reply: ive got a pretty serious fuse prob
