ivan fenders
ivan fenders
ok im pretty sure the ivan fenders wont match up to the stock hood right? 94 toyota pickup 2wd. but wanted to clarify this becuase i heard that hanneman, glasswork and fiberwerx's versions are all a little different, so would anyone of those brands work with stock hood, sharp corners. or do u guys no of any fenders that flare up alot like the ivans, that i can just get fiberglass fenders with stock hood lines. thanks. try not to get on me about the search bar thing cus i tried but i wanted to double check.
you should try the search thing... and stop bitching about it.
I found this with search http://toyotafiberglass.com
do they have something you might be interested in?
u didnt answere the question
i wan't to know if the hanneman , glassworks, or fiberweX ivan fender models match up to the stock hood, i dont think they do but if anyone has a picture with the ivan fender up to a stock hood.
No one has a picture because it doesn't line up and looks lame. Ivan hoods have a flare on the outside to match fender. They are all pretty much they same. Hanneman's probably are the closest fit from what I've seen on buddy's rides. You can always just build the hood up with a little bondo if you don't want to spring for the matching hood.
That looks sick 2020! He is curious about the Ivan fenders that have the bulge that goes above the hood line, which I couldn't find on Glassworks site. They don't quite line up like yours do with the stock hood.
the only way you are going to get the ivan style look with a stock hood is to use the hannemann 4'' flat top fenders. it doesnt have a bulge on top but it is flat and dosent roll with the body line of the stock fenders. you will have to switch to 4x4 corners though.
ok i did like the flat top look, but my truck is 2 wheel drive and the flat top shown in the picture is for the 4 wheel drive. so are the mounting points different or what?
ill put a picture up of my truck tommorrow, i just went ahead and cut my stock fenders up to make room, hanneman wanted 435 shipped, and that was just to much for me , the service was excellent tho on the tellephone.
call downey, they have the flat top fenders http://downeyoff-road.com/BodyCompon...ssFenders.html i got my fenders from them for $335 shipped to my door. all the mounting pints are the same, and like i said before you will just have to get the 4x4 corner lights. you can get them from ebay for pretty cheap too. i wish i had gone with the 4'' flat tops but all well. they will be my next set.
live4soccer7
05-11-2016 06:52 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
