It's a sad day.....
It's a sad day.....
So yesterday I had an accident, I'm afraid it could be totaled. If not what do you guys think a hood, quarter panel, bumper would cost? Upgrades I could do to make a bad situation better? I only had liability so I'll have to pay out of pocket. It's a sad sad day.
I know exactly how you feel, same situation with my 4runner. I am so glad I fixed it though. Maybe look into a newer year model front clip swap, I did. I lost some of the classic look but I also lost the sealed beams
ouch.. been there once my self.. except i rolled my 85 pickup at about 50mph headin to work one morning.. i also just had liability at the time (what was worse is that i had just talked to my dad about upgrading to full coverage after the end of the month) and had just finished doing all the body work to the bedsides and had it all primed and ready for paint. i guess if i were you id start hittin junkyards up to find some parts, even check craigslist to see if anyone is parting anything out. your core support looks like it could be damaged to.. there really not to bad to replace.. just takes time and patience.
I've repaired much worse. I have had to tug the frame horn a bit, and have 'em double checked on a frame machine, but it's not too bad. Also, it's a good idea to check around for a halfway decent body (blown motor or none at all even) for sale cheap. Even a rear ender that has been totaled out, and not only could you get all of your front end parts, but even some other goodies you might need or be able to sell off to recoup some costs!
Fixable.
Find a good parts truck, and slap it on, bend it back and weld a little if you ahve to then go to macco and get a cheap paint job. If you can't find good replacement parts go to certifit, new fender is $60.
Been there with the "would have been totalled" and "only had liability" situation last year.
Mine was a little worse than yours in that I needed to cut off a radiator/body mount and replace it in addition to the body panels and radiator supports. Also my frame took some tugging and the inner side fender supports needed to be pulled back over. Anything's fixable and you can bring it back 10 times better. It sucks and takes time and money but you can look at it as an opportunity I guess... I almost junked mine but I wouldn't have had a truck I was happy with for the cost of repairs. So glad that I didn't. I might still have some of the radiator support pieces I bought but didn't need as mine were repairable. I'll check, if I do you can have them for shipping cost.
I got rearended at a stoplight by a yeahoo talking on a cell phone. At the time, I had full insurance coverage. When I got a repair estimate, I discovered that the body shops were going to fix the damage using used parts. I was told that after a vehicle got so old, repairs are made with used, not new, body parts. The money I paid for comprehensive insurance coverage in two years would have covered the repair bill.
If you have the ability to buy and install used body parts, like many of the posters have stated, you can be back on the road with a little effort and a moderate amount of cash.
You can see the full size images here http://www.flickr.com/photos/3002747...094401/detail/
Cut off the whole front-end and tube it! HA, just kidding. From the photos, it looks like you hit just hard enough to smoosh the front but not bend the frame (i hope). Just lay under the truck with a BRIGHT light and look for any tweaks in the frame/mounts etc. I had minimal tools and had no experience when I did my front end that I smashed. It's just a matter of patience and leverage. A bottle jack and gentle heat works great for the first couple of steps to get the headlight mount going in the right direction. Or cut off the bent stuff, buy some new stuff and have a mobile welder come out and tac it on for ya.
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
I have everything you need to fix it less a fender, if you are interested. my bumper is pitted a little, but still intact. the vehicle is going for parts and I can cut off anything you want!
click the link in my sig for the specs or PM me if you are interested!
and def. rebuild it! You won't be sorry. I rolled my old 90 back in the day and we just junked it. I regret, deeply, that decision to this day...
No, I dont have actual links to this. But these are the average prices for used/aftermarket parts I have seen online.
I did this to my truck right when I got it... Not as bad as yours, but I had never done any repair like that before.. Very easy!!
So I got my truck back from the shop Monday,(had to get the frame pulled) and have been driving evreyday since then. This morning I was going down the road and it dies. I pull over and it acts like it's not getting a spark/fuel then starts after a few tries. Drive another couple miles and the same thing except this time it takes about 30 minutes, i checked all the fuses, plug wires distributor, still won't start. Then i pull the plugs on the igntion coil/ignitor and the look ok so I plug them back up and it starts on the first turn. Drove the remaining 8 miles to work no problem. I figured I was going to have some gremlins released after the wreck. Any ideas what this one might be? (The ignitor is about 3 months old).
Looks like your underhood fuse/relay box got dislodged during the wreck. I'd start there making sure nothing is loose.
You also describe what my truck did before the fuel pump went out. When it dies does it sputter and die or act like the key was turned off?
