| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
ISR mod supplies questions
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 246,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 Last edited by Jay351; 08-27-2007 at 05:08 PM. |
#2 (permalink) |
**subscribed
__________________
95 4runner 2wd 3.0 v6 Downey headers (dont buy them) Downey 2 1/2" full exhaust/Carsound cat Weasy2k cams/ENGNBLDR's o/s valves ported and polished heads/intake New project- 94 4runner V6 4x4 A/T 3" 4Crawler BL on order 33x12.5 BFG A/T's on 15x8 Cragar Black Steel Wheels 90 4runner 4x4 3vze Auto parting out - let me know if you need anything! 85 4runner, SFA, 22re, 5speed parting out |
#3 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
A couple questions...
Do you mean the inside diameter is 2.75ish and the outside is 3"? And.... Do you have a radiator shop around where you can get large radiator hose...like for heavy trucks or farm equipment? Or is rad hose what you used? The ABS will likely work. It's fairly thick. Over a period of time it may get brittle from being exposed to the heat, but it should last a good while until you have other options. I'm just surprised that's all you can find, though. Surely you have large home improvement/hardware stores around...no??? Anyway, you could actually cement the ABS pieces together making one piece. It would be sturdier than just silicone. The brass fittings? It depends on what you have in mind. The way I see it, you should be able to just use the stock vent tube hose clamped to the vent port on the cover and then use a fitting to the ABS...and for that you could use brass. I did. I just drilled a hole in the intake tube (PVC) and threaded the brass fitting directly into it. No glue, sealant, or backing washers necessary. Same for the other hose. Listen... If you like, I can help you out with supplies bypassing all the troubles you're having. I can get a price on materials for you and shipping estimate. I'm very sure it would be a lot less than $50.
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
#4 (permalink) |
The inside diameter of the ABS pipe is 3" but the outside diameter of the throttle body and airbox is 2.75.
therefor a simple radiator tube wouldnt work as it would creatle wrinkles when compressed thus creating leaks. I have gone to the big chain stores except for 1. (RONA) I will go there tomorrow to see if they have the reducers. As for the brass fittings. They are simply a straight fitting (couldnt find any 90 degree ones) that is threaded on one end and barbed on the other, I just wanted to make sure copper would be okay and wouldnt be a problem with the engine ( I think they are copper, not really sure. I know brass is okay but I just want to cover my butt here) My tube setup routing will work good with the bend in the middle and allow a little more access to the oil dipstick as I have seen others impeeded the access. Thanks for your offer of getting the parts for me, I might just take you up if I can't find these couplers in this big chain store tomorrow. Thanks for your help!
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 246,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#5 (permalink) |
i just went to a muffler shop and had them bend the pipe, then i went to ace and found some pipe that fit my crank case breather hose, had them drill a hole in that part of the pipe, weld it.. same on both. then took some cheap rubber plastic connectors from orielly's and band clamped them to the plenum and air box. tim.
__________________
91 sr5 3SLOW auto xtra cab 4x4 : K&N air filter, isr mod, new exhaust, rebuilt tranny @ 237k miles. 31x10.5x15 dayton mt, combo kit brush guard with kc lights, 20% tinted windows all around, panasonic cd player & all new speakers, max 4 seat covers & floor mats, sirius satellite radio. Running strong @ 250k miles. Headgasket replaced @ 239k miles. |
#6 (permalink) | |
I'll bet the fittings you have are brass. Copper isn't generally used for making parts like this. It isn't resiliant enough. Regardless, if the parts have any labeling whatsoever it should say.
I see what you mean about the hose. Yeah, I ran into that same problem originally. So, the PVC I settled on buying had the same inside diameter as the TB and airbox, but was just a hair large on the OD. So, the rad hose I bought was perfect. Maybe you've seen the pic I posted on the set up I went with? It's floating around in one or two of these IRS mod threads. Well, let me know what you decide or what you can find. I can get whatever you need without paying taxes. Don't worry...it's legit. I have bonified tax exemption with the work I do.
__________________
#7 (permalink) |
I have seen the pictures you posted but I couldnt get much from them.
Nobody seems to post any close up pictures!! But anyways, I will go to RONA tomorrow and hopfally they have somthing I can use. I will post up my findings then, but if anyone has anyother suggestions or comments, post away. The local shops have been 0 help with this subject. Im sure if I told them I was using sewer pipe for an intake they would laugh!
__________________
#8 (permalink) | |
Quote:
__________________
#9 (permalink) |
Went to 2 other stores today but no luck! Nobody has these fittings!
Thook, if you could see if you can get these kind of fittings. I need 2 flexible reducers that go from an inside diameter of 3.5" to an inside diameter of 2.75" Thanks!
__________________
#10 (permalink) |
__________________
-- '90 4Runner 2Dr 3.0 / sas /OME 860 coils / rear e-locker / 32's/ MC Rear bumper / TG Sliders / surco basket / cobra 18 wxstII / ISR / Magnaflow exhaust |
#11 (permalink) | |
Quote:
thanks for the link, yeah I know about the size being not very common
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 97 SR5, 2.7 L ISR questions and Grey Wire mod question | Kintore | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 07-12-2007 12:14 PM |
| isr mod...again | 89red4x4yota | 86-95 Trucks & 4Runners | 3 | 03-20-2006 03:14 PM |
| 2 Questions on ISR Mod | dreux13 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 04-26-2005 12:17 PM |
| I am about to do the ISR mod | wvuviv30 | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 05-17-2004 10:25 PM |
