irab88's battery/intake swap
Old 10-22-2010, 11:11 PM
  #81
myyota's Avatar
Originally Posted by yeehaw1
Okay, makes more sense now, A
couple more questions though, what exactly is the AFM? what does AFM stand for? And since this afm thing deals with airflow, is the power gain similar to adding a header, performance exhaust, orcold air intake box?
AFM = air flow meter, its the thing mounted to the air filter box with the electrical plug on it. I don`t know if you will see gains similar to adding a header, but you will get better acceleration and you will have more power on the highway climbing hills or passing.
Old 10-22-2010, 11:26 PM
  #82
yeehaw1's Avatar
So my guess was right, I was wondering what that plug was for! So in order to do this do you need to relocate your airfilter as well? You and irab have picked
my interest tonight. Better acceleration uphill would be nice,
maybe then I wouldn't get passed by semis. Lol. I guess the oldsaying you learn something new everyday is true.
Old 10-22-2010, 11:41 PM
  #83
myyota's Avatar
I see your truck has an automatic transmission, that in it self is hurting your power output a lot. The AFM upgrade and a header and exhaust would help you a lot, if you have larger than stock tires regearing will also help a lot. I just took the larger AFM off of my 4Runner because im getting ready to put on a 90 22RE upper intake, and do the battery / intake swap. The 90 22Re upper intake has better air flow than the early upper intake because its not angled.
Old 10-23-2010, 05:07 AM
  #84
irab88's Avatar
in a stock setup, the ai...
dammit, he beat me to the punch! haha
Old 10-23-2010, 07:02 AM
  #85
shaeff's Avatar
Originally Posted by irab88
update on the intake:
it works. maybe too well. as it got below 40 last night, i turned the heat on. nothing. i waited 10 or so mins before it started to warm up. but it was purrrrrrrrrrin' cruising up the freeway, so i'm not upset. the temp gauge barely makes it to 1/4 of the way over (as opposed to the usual 1/2). i know it works. and as for the mileage, it's back up to normal. i had plugged my plenum valve, so i put the hose/filter back on, which did the trick. i think i'll techron the system next week
The intake setup has absolutely nothing to do with heater output. I've been running with my intake swapped for a few years, year round and my heat has been completely normal. I also have no PAIR and no EGR (though I should have kept the EGR, but that's another story entirely)
Check your coolant level, thermostat, and heater valve.
Old 10-23-2010, 07:57 AM
  #86
irab88's Avatar
i think it was just the fact that i didn't have a coat on . it's fine now.
also, coolant stuff is fine, so no issue there
Old 10-23-2010, 02:55 PM
  #87
shaeff's Avatar
Huh. Is the heat in your truck good? I mean, I can be in shorts and short sleeves in the dead of winter in my truck with the heat on and it still gets too hot inside.
And if it took a while to get up to temperature, sounds like the t-stat sticking open. Anyway, glad to hear it's working well for ya.
Old 10-23-2010, 04:49 PM
  #88
irab88's Avatar
yeah, i think it was a bit too chilly for me for a bit. the heater works well and all.
another thing to consider with this mod (in general) is that more air can flow around the block, without the intake hose in the way
Originally Posted by shaeff
Huh. Is the heat in your truck good? I mean, I can be in shorts and short sleeves in the dead of winter in my truck with the heat on and it still gets too hot inside...
same thing here, but i rarely wear shorts in the dead of winter lol
i'll check it out. it seems as if things are slowly breaking. the fill bolt on the trany is stuck now, and the new cat i ordered is 4.5" too short
Old 10-24-2010, 07:59 AM
  #89
shaeff's Avatar
LOL, I try not to make a habit of it either, but sometimes I don't feel like changing before leaving the gym if I'm just going straight home.
Old 10-24-2010, 02:52 PM
  #90
irab88's Avatar
haha ok, so there is method to your madness
Old 10-24-2010, 03:37 PM
  #91
shaeff's Avatar
Usually! Haha!
Old 12-20-2010, 04:56 AM
  #92
tankyota's Avatar
It'll be fine
Originally Posted by Duelertoyota4x4
The biggest concern i have here i the placement of the AFM. Those are some sensitive pieces of equipment there and im not convinced that its gonna run right mounted upside down. Keep us informed.
Didn't finish reading the rest of this thread, but I saw a couple people wondering if the AFM would be fine mounted upside down. I just got finished rebuilding and fixing mine and don't worry, it will be fine upside down.
Old 04-25-2011, 08:57 PM
  #93
skoti89's Avatar
Bringin it back to life!!lol
How is it still holding up? Still liking the changes?
I am still thinking about doing this. It doesn't seem like it could hurt anything.
Old 04-26-2011, 07:00 AM
  #94
irab88's Avatar
it make accelerating at-speed a bit better, and it sounds cool. you can put your hand next to the filter and actually feel the air being sucked in. i like it, but i wish i had gone with black fittings instead of red.
also, since you have an earlier model, the air conditioning lines won't stick up like mine. this means you might be able to get away with fewer fittings and a longer filter. i still need to build a brace for mine, but it works just fine. definitely worth it. took me a weekend, probably less if you have all the parts ready to go
Old 04-26-2011, 07:43 AM
  #95
BigBluePile's Avatar
Mine still works great.
Old 04-26-2011, 04:13 PM
  #96
shaeff's Avatar
Mine has been fine for a few years.
Old 04-26-2011, 11:49 PM
  #97
Aussie22r's Avatar
Do you have a shopping list of hoses and pipe?
I dont have to fit in the AFM so length isn't much of an issue
Old 04-27-2011, 06:00 AM
  #98
irab88's Avatar
i'm puzzled as to why you wouldn't need an afm
in any case, what would probably work for you would be:
-a 90 degree 3" to 2.75" silicone elbow
-a 3" aluminum coupler
then you would find an air filter that would fit, one with a 3" opening
http://siliconeintakes.com/
Old 04-27-2011, 11:57 AM
  #99
Aussie22r's Avatar
Megasquirt!!!
Old 04-27-2011, 01:22 PM
  #100
irab88's Avatar
cool. good luck, then!
Quick Reply: irab88's battery/intake swap
