Intake manifold/thermostat leak- broken bolt - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-16-2006, 05:13 PM   #1 (permalink)
Hi All,
My 22re (88 pickup) with EFI has a problem that I gave it. A simple thermostat replacement turned to a broken bolt, followed by bad drill out, resulting in large hole in aluminum (7/16"). Now, I cannot get a seal with water outlet and intake manifold. A mechanic said I needed to repace the lower intake manifold. Is this totally necessary? He said that it cannot reach it to welded it shut (no problem for future since if therm ever goes bad, THEN I replace the intake manifold). He also said heliocoil won't work...Thoughts?
Thanks
John
jbhashem is offline
Old 05-16-2006, 06:13 PM   #2 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
i would say just go to a junk yard and pick up a intake manifold
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 05-16-2006, 06:32 PM   #3 (permalink)
trythis's Avatar
oof, I did the same ,but the drill out went better than that. I second the junk yard approach.
trythis is offline
Old 05-16-2006, 11:11 PM   #4 (permalink)
wrenchmonster's Avatar
Hummm. Do you have a picture. Although not a good idea overall, could you get away with some epoxy and a keen-sert? I don't think the torque spec is very high for the stat. Por-15 has a few epoxy products and even an aluminum paste I believe.
Could you tap out and use a slightly larger bolt to hold the stat housing? Are there threads deeper than the original bolt? Could you catch those threads by using a longer bolt? How about a weld up and re-tap?
I'm not at all advocating a shoddy repair, but just trying to brainstorm some possible ideas.
wrenchmonster is offline
Old 05-17-2006, 03:27 AM   #5 (permalink)
Great ideas
Thanks for the great ideas. I don't have a pic and truck is at a shop. I will look into some of the products discussed. I used cold weld but the vibrations of the engine are too much for the weld to hold. I can fit 7/16 in but have been unsuccessful at tapping new threads. But, it is probably worth to try again.
jbhashem is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
3.0 Coolant Leak Under Intake Manifold Gurney Newbie Tech Section 9 06-09-2007 06:28 PM
Intake Manifold Leak maybe? Experts needed! AllTimeHigh 86-95 Trucks & 4Runners 1 11-27-2006 07:27 AM
22RE intake manifold coolant leak -Please help... 95g ATL 84-85 Trucks & 4Runners 3 05-02-2006 05:58 PM
2009 InternetBrands, Inc.
