intake manifold gasket for turbo 4runner
Old 10-13-2007, 05:58 AM
swerks's Avatar
Question intake manifold gasket for turbo 4runner
can any one tell me if the turbo 22ret engine takes a different gasket ?? if so do you have a part #, or know where I might purchase one.
Old 10-13-2007, 06:18 AM
JamesD's Avatar
Same gasket as the 22RE.
James
Old 10-13-2007, 08:08 AM
dcg9381's Avatar
Look on ebay or LC Engineering for a "insulating" intake manifold gasket - it's made out of a plastic composite and won't get crapped due to water - totally reusable. They sell it as something to increase HP (lower intake manifold temp) - but it's really no good for that purpose.. great for boosted trucks though.
Old 10-13-2007, 10:52 AM
n4ynu1010's Avatar
Plastic Composite , radiators and now head gaskets , someone shoot me please ...................
Old 10-13-2007, 04:43 PM
89 toy's Avatar
they are different i got one at napa $42.00
Old 10-13-2007, 05:07 PM
dcg9381's Avatar
They are not different. The port setup on both manifolds is the same.
$42 is ridiculous to spend on that gasket.
A basic paper gasket will work - and if NAPA is charging you $42, I'll send you one for $15 as I've got about 3 sitting in the garage. I replaced my paper gasket as my manifold got a little loose after the rebuild and heat cycling - the radiator fluid actually degraded the gasket quite a bit.'
10+ psi through wasted paper gasket isn't good..
Old 10-14-2007, 08:48 AM
swerks's Avatar
any body using one of these plastic gaskets or the one from LC engineering thats teflon???
Old 10-14-2007, 10:03 AM
dcg9381's Avatar
The one I have might be teflon - it's white.. is that what they're selling?
Old 10-14-2007, 10:32 AM
n4ynu1010's Avatar
Head Gasket
Put the part # on Google and see then look at a few sites and see if that is what they are selling and get the specs on it .
Old 10-14-2007, 10:37 AM
ozziesironmanoffroad's Avatar
now if only asbestos wasnt illegal to use.... could make some bada$$ gaskets
Old 10-14-2007, 11:00 AM
n4ynu1010's Avatar
Asbestos Good - EPA Bad - you know your not supposed to breath it , so wear protection and enjoy
But Nooooooooooooooooooooooooo , down with the EPA hehe , ever notice all the bad stuff is what worked the best .
Old 10-14-2007, 07:27 PM
89 toy's Avatar
i read it wrong i thought it said exhaust manifold gasket
Old 10-15-2007, 02:02 AM
swerks's Avatar
The white ones from LC are teflon and cost $42.00
Old 10-15-2007, 08:09 AM
n4ynu1010's Avatar
Head Gasket
Well at least they are Teflon , I just can't imagine a plastic head gasket geesh , tell me its not true
Old 10-15-2007, 05:13 PM
dcg9381's Avatar
This is what I purchased:
http://www.precisionpowerparts.com/s...=0&i=134642226
Old 10-15-2007, 05:22 PM
n4ynu1010's Avatar
Oh Intake Gasket hehe , I thought we were talking head gasket
Is that supposed to lessen temp transfer also , is that one of the reasons it is teflon ?
Old 10-16-2007, 09:52 AM
dcg9381's Avatar
That's what the advertisement says. I seriously doubt if there is any difference at all.. Insulation prevents slows the rate of heat transfer, after a certain amount of time that heat is coming over to the manifold anyway...
It's good as a reusable gasket though!
Old 10-16-2007, 11:15 AM
n4ynu1010's Avatar
Intake Gasket
Cool , was just curious , I would imagine it would also flex a bit more and would not get hard as a rock and maybe be a bit more leak resistant
steve miller
10-10-2015 01:40 AM
Whatever123
09-30-2015 12:12 AM
MTLroadierunner
07-15-2015 12:58 PM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: intake manifold gasket for turbo 4runner
