Instruction on valve adjustment 22re
Old 01-29-2008, 08:30 AM
89whitetoyota's Avatar
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
I set them with it cold first, and .20 (intake) and .30 (exhaust), and wow, the level of noise completely left. It no longer sounds like a diesel, even though I really wish it was. I had bought a new head so some of the valves were really wacked out, and just with a prelim adjustment the motor idled perfect (where before it would have a slight miss), and power through the gears seemed more consistant and tight.
Then did it again after warming it up and presto, the truck is running better than ever.
Thanks for all of the help here guys, and 4Crawlers link on this made it super easy for a first time learner on valve adjusting.
Old 01-29-2008, 06:17 PM
84sr5yoty's Avatar
I'm assuming you mean .02 and .03. Either way, say bye bye to your valves if you want to run those tolerances. You shouldn’t go any tighter than .006 on the intake and .010 on the exhaust.
Old 01-30-2008, 07:21 AM
I was describing inches on the feeler aspects which translates into the standard 8(intanke) and 12(exhaust) in MM specs. The truck is set to FSM specifications.
Old 01-30-2008, 07:59 AM
MMA_Alex's Avatar
you mean you were doing mm. its .008in intake .012in exhaust, which is .2mm, and .3mm
Old 01-30-2008, 08:11 AM
  #25
right, I apologize for all of the confusion. MMA you're right. Just for clarification, if anyone clicks on the link 4crawler gave me a couple responses up, those are the exact specs I set it to.
I forgot a couple zeros in describing the gauge i used, that was my bad.
Old 02-04-2012, 10:43 AM
  #26
jmitchell2008me's Avatar
how long does this take like the whole procedure and on a another does rtv black set up if it like freeze cold outside like maine in winter
sandyota
02-04-2021 11:16 AM
coleypull15
11-03-2015 07:41 AM
09-04-2015 09:27 AM
razorman8669
07-12-2015 12:13 PM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: Instruction on valve adjustment 22re
