| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Installing engine tomorrow, need help
#2 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
Um....drop the driveshaft?......
<<<ducks as wrench is thrown<<<
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
#3 (permalink) |
Thanks thook. But why was I able to put the truck in neutral before. <<laughing as I throw the wrench>>
#4 (permalink) |
In my 2004 the key has to be in the on position and the brake drepressed to shift from park. It's a safety thing. However there is a small cover by the P onthe shifter, left side. Pop the cover off and depress the small button. You should be able to shift it to neutral. It is a shifter lock bypass for towing etc without the key.
__________________
2004 Double Cab Tacoma 4X4 3.4L TRD Offroad, Rear stock E-Locker, ARB Winch Bumper,Warn 8000, Flowmaster exhaust, 2" Daystar Lift, Blue LED Back/Instrument Lights. |
#5 (permalink) |
Thanks Orem, I will check that out in the morning. If not, I guess I will have to drop the drive shaft..
#6 (permalink) | |
Do what he suggested. (Good posting!) As you long as you have power to the system, you should be able to. It's the same in my wife's '92 auto. I do believe it's the same for any automatic ECT unit.
__________________
#7 (permalink) |
my hilux has a red button on the auto tranny if i press this i can shift whenever! has some japan writing beside it like everything!
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan, 130,000 km 31 bfg a/t auto current build 1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/ |
#8 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
umm... what? you used to be able to but now you can't?
huh? pull the shifter and move the linkage manually.
__________________
Quote:
Insomnia: it's a way of life.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| how do you line up engine mounts after installing headers? | Texas_Ace | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 11-08-2008 08:52 PM |
| Installing a 22r engine | 87yoda87 | 86-95 Trucks & 4Runners | 14 | 06-21-2008 11:17 AM |
| Installing Coolant style Engine Block Heater | Skrillah | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 11-02-2007 03:51 PM |
| I have tell tomorrow. | SearchN | General Electrical & Lighting Related Topics | 0 | 02-12-2006 11:06 AM |
| Installing Aisans tomorrow.. anything I need to know? | UKMyers | 86-95 Trucks & 4Runners | 7 | 02-05-2006 12:22 PM |
