installed 3 gauge pillar pod (pics)
installed it using one pillar from http://www.truckpillars.com/index.html and autometer gauges from jegs.
i decided to put the sender before the radiator and the additional cooler in the rubber line. so i made this out of brass fittings. notive the grounding wire placed underneath the neck of the sender.
then cut and positioned the assembly in the rubber line.
then drilled a hole and grounded it to the frame and ran the sender wire up to the pillar.
then installed all 3 gaudes. i have a mini tach(no tach in cluster, tranny temp, and volts(for when i install subs) i also have a fuel pressure gauge under the hood.
feel free to ask any questions and comment
I found one downfall to this kit, when I installed mine yesterday the sunvisor hits it!!! lol. Other than that it's a great product, great fit and finish.
I looked at the website posted for the gauge pods and they only sell pods for 1st and 2nd generation 4runners....If anyone is interested in doing this mod for a 3rd or 4th generation 4runner you can find the gauge pods here:
http://www.gaugepods.com/toyota.html
Another thing to consider is that this website offers the pods in different colors (black, factory oak, and factory gray) which is I think is pretty cool....It is my understanding that the "factory" colors are not an exact match but are pretty close.
I just ordered my gauges (from Jegs) and pod (from the website above) a couple days ago and I plan on getting everything installed as soon as I receive everything. I will post pics when I'm done.
question.......my cousin is wiring up a similar setup...he wants to put water temp and 2 others.....hes not sure where the water temp line goes....? any suggestions are greatly app.
for a digital fuel level gauge, you need a digital signal sender from the tank. Make sure whatever gauge you purchase comes as a complete set, or you will have a heck of a time making things work together.
Let us know here if you find it, it's interesting.
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
Poncho0206
07-10-2015 06:21 PM
crashburnoveride
07-10-2015 06:39 AM
